WINPILOT + ILEC SN-10 + VOLKSLOGGER
Old December 23rd 05, 09:23 PM posted to rec.aviation.soaring
Default WINPILOT + ILEC SN-10 + VOLKSLOGGER
Calculation of windspeed and wind direction without circling:
Here's my understanding. If it's not correct, doubtless someone will
straighten me out and I will have learned something. DISCLAIMER: I have
absolutely no "inside" information on the algorithms used in the SN10!
Aircraft heading (direction the nose is pointing) and airspeed together
define a velocity vector that can be drawn as an arrow on a piece of paper,
the angle of the arrow representing the direction and the length of the
arrow representing airspeed. Starting at the tip of this arrow we can add a
second arrow representing wind speed and direction. If we now draw a third
arrow that closes the triangle (from the start of the first arrow to the end
of the second) this arrow represents the aircraft track (direction of travel
over the ground) and ground speed, this being the classical "wind triangle"
well known to pilots. Note that defining any two of the vectors of a wind
triangle automatically defines the third, this vector (like all vectors)
being defined by its magnitude and direction.
The above describes the graphical addition of two vectors.We can also do
vector addition (or subtraction) mathematically, instead of plotting arrows
on paper. The key point here is that the six quantities involved, aircraft
heading, aircraft airspeed, wind direction, wind speed, ground track and
ground speed define three vectors that are related mathematically by a
single (vector) equation:
In the case of a sailplane with an SN10 that has input from a GPS, we have
three knowns, namely true airspeed (the SN10 can compute this from pitot
pressure, static pressure, altitude and temperature), groundspeed and track
(the last two come from the GPS). There are three unknowns, aircraft
heading, wind direction and windspeed. Basically, multiple unknowns can be
calculated by setting up and solving simultaneous equations. There are well
known mathematical and computer algorithms for doing this.
If we make the assumption that the wind direction and speed are constant (at
least in the short term, and within a given altitude band) and if (in the
same short term) the sailplane flies on two distinct headings and / or
airspeeds within that altitude band, we have two different sets of "known"
values to insert into the vector equation. We can treat the resulting
equations as simultaneous equations and solve for the above-mentioned
unknowns. For the best result, the headings and /or airspeeds should be as
different as possible. Theoretically, we can get a unique solution as long
as the headings and / or airspeeds are not absolutely identical, but in the
real world, it appears that (at least sometimes) we need significantly
different headings to get a reliable result. Bear in mind that the even if
the windspeed and direction are indeed constant, the three "known" values
are not known with absolute precision and computers always introduce
round-off errors, some of which can get to be significant in these types of
calculations. Remember too, mathematically-speaking we are cheating. The
"known" values that are plugged into "simultaneous" equations should really
be values that are measured simultaneously! In this case, they are not, they
are values derived at different times and places, the main effect of which
is to make it more likely that the initial assumption of constant wind speed
and wind direction is not quite correct.
If we continue to fly in the same altitude band, with new headings/
airspeeds, we can get new and different input values that can be plugged in
and solved for new values of windspeed and direction. For the reasons stated
above, these results will not be all the same. If the results are clustered
closely together, we can have a high confidence in them. If the values are
all over the place, we can still display a value for the user (pilot), e.g.,
by averaging a number of results, but we will have a low confidence in the
displayed values. (Note: the SN10 does indeed display a confidence value for
each calculated wind speed and direction).
Advantages over windspeed and direction calculated from circle drift:
there's the obvious one that you don't have to circle to get a result.
Additionally, a circling sailplane pilot will often be moving his circle to
get better centered, and such shifts adversely affect the wind calculation.
And anyway, who ever flies perfect circles?
Disadvantages? In practice, the method does seem to require significant
heading changes and sometimes (e.g. some ridge flying, straight line cruises
between thermals, some wave flights) these are just not available. I have
flown with an SN10 for several years and sometimes found it necessary to
make one or more deliberate heading changes to get a calculated wind that
makes sense. If an accurate aircraft heading sensor were added to the SN10,
thus completely defining two of the vectors in the "wind triangle", this
would not be necessary. One lives in hope...
Ray Roberts
Well, I could explain but then I'd have to kill you ;-)
I'm really not sure what algorithms other software
currently uses, but my understanding is that we
have a big advantage by using ASI as well as GPS.
Happy Holidays and Best Regards, Dave
MaD wrote:
My experience is that the wind calculation of the SN10 is extremely
reliable and accurate. I reckon WP is as good as any other device
calculating based on circling drift only, like the LX20 for example. I
often compare SN10 and LX20 values and normally the SN10 is far better.
I'm sure Dave N. can explain why.
Marcel
Old December 24th 05, 07:58 PM posted to rec.aviation.soaring
"Ray Roberts" wrote in message
paper, the angle of the arrow representing the direction and the length of
track (the last two come from the GPS). There are three unknowns, aircraft
well known mathematical and computer algorithms for doing this.
SN10, thus completely defining two of the vectors in the "wind triangle",
this would not be necessary. One lives in hope...
For $300 you can add a fluxgate compass that will communicate via NMEA...
Fixing the software to use it would be up to you.
Of course, the heading information will only be good when you are flying
straight and level...
http://www.westmarine.com/webapp/wcs...001/606/137/14
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
Old December 24th 05, 08:58 PM posted to rec.aviation.soaring
Having good heading info only when flying wings level is not that big a
problem, since the present SN10 algorithm works fairly well when one is
turning. One could just switch back to the present algorithm for turning
flight. Maybe that's what the Zander does (a previous poster said he didn't
understand how the Zander, which uses a heading sensor, can calculate wind
when the sailplane is banked).
Ray
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
news:GLydnQkwE87RNTDenZ2dnUVZ_sCdnZ2d@wideopenwest .com...
Snip
If an accurate aircraft heading sensor were added to the SN10, thus
completely defining two of the vectors in the "wind triangle", this would
Old January 8th 06, 06:29 PM posted to rec.aviation.soaring
I actually have the same Azimuth 1000 flux gate compass installed on
the rear instrument panel of my Janus C. It is coupled via NMEA to an
RMI microEncoder in the front panel.
One problem with the set-up is that the S/H two-place one-piece canopy
has a steel cross member, so the compass reading changes by more than 5
degrees between open and closed canopy. Also, even though it is tilt
compensated by mounting the flux gate on a gimball, it does not produce
consistent readings when tilted. I assume this is because the tilt
compensation alters the hard/soft iron compensation.
I looked at installing a remote flux gate, but there is no place in the
glider to mount it far enough from the steel flight control push/pull
rods. This is a real problem for getting accurate heading info from a
magnetic sensor in a glider.
P.S. Ray points out that with any two vectors, you can draw the vectors
tip to tail to complete the wind triangle. With one vector (GPS) and a
scalar (TAS) you can draw a circle around the tip of the vector to
create a family of wind triangles. With a second set of measurements on
another heading, you can draw another circle which intersects the first
at two places. With another set of measurements, you can remove the
ambiguity, and get a check on the error. In practice, flight computers
like the SN-10 make lots of measurements and keep a running calculation
of the wind by filtering out the measurement errors.
Geoff
Old January 8th 06, 05:06 PM posted to rec.aviation.soaring
Geoff
WinPilot offer... and UK news Paul Crabb Soaring 2 February 19th 04 09:22 AM
Volkslogger, LX160 and WinPilot ADV Michael Nyrup Soaring 1 November 24th 03 06:21 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
Declaring a flight in WinPilot to the Volkslogger JohnD Soaring 0 October 1st 03 11:55 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
