Before you do anything, you might want to check to see if your engine falls
under the expanded AD for the Lycoming O-360 crankshaft recall. With regards to shop selection, I can recommend against Magnum engines in Ohio. They are absolute crooks. "Maule Driver" wrote in message .. . Based on the appearance of metal after 1,100 hours (filings in the filter and doubling of FE content in 36 hour oil analysis), I'm having my Lycoming o-360 taken apart. Two major choices to make: 1) Overhaul or 'look, see, fix'. That is, I could just go for an overhaul (est $12,000 for 2,000 hours) or LSF (guesstimate $6,000k for 900 hours). Of course there may not be a choice... 2) Shop selection. My mechanic is somewhat shop agnostic - they work with Signature in Ohio and Mattituck. Your thoughts and opinions are valued. |
I think you are referring to the corrosion AD for o-360s with a CS prop?
That particular one doesn't apply to me since I have a fixed prop with a solid crank. Thanks GE wrote: Before you do anything, you might want to check to see if your engine falls under the expanded AD for the Lycoming O-360 crankshaft recall. |
Maule Driver wrote:
: I think you are referring to the corrosion AD for o-360s with a CS prop? : That particular one doesn't apply to me since I have a fixed prop with : a solid crank. I was going to mention that but figured you already knew. IIRC, one can treat the hollow crank to have it terminate the AD. With a solid crank that one should be fine. There is, of course, the sintered iron oil pump AD... and a rash the connecting rod bolts from Superior IIRC. Seriously though... if you've got the bottom end apart, you'd be silly not to spend the extra bit to get the steel parts magnafluxed. That's about the only additional thing you'd have to do aside from what's *required* after you split the cases, but it's enough to call it a bottom overhaul. From the sounds of the metal, you'll likely be buying a new cam. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Chevy LS2 and Trans??? any real issues besides weight | MrV | Home Built | 82 | November 18th 05 03:11 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Engine Sizing and Selection | Toks Desalu | Home Built | 27 | November 6th 03 05:24 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
