#11
Vaughn wrote:
"Gary Boggs" wrote in message ... I think undoing the occasional knot in the rope is far safer than the possibility of getting tangled in the end of the rope. Is this practice used anywhere else in the world? Please give me some feedback. It would have to be a pretty wild "soft" release to result in a glider tangled in the tow rope. That said, I know of one nasty accident that resulted from the apparent failure of a glider pilot to confirm release. Our site always stressed that the glider must not move out of position until the glider pilot has visually confirmed rope release. But it is far harder to visually confirm release after a soft release because the ring tends to dangle out of sight below the glider's nose and there is no rope "snap" to observe. If that's the case, you're putting *a lot* of slack in the rope. You can always fly a bit off center just before release so the rope is more visible. The same technique works in slack line recovery too. ;-) Jeremy |
That sort of technique may well work if you have a pre-planned release
altitude as on training flights in no lift. The time it takes to recognize a thermal, and release in it, is far too short to reposition the glider, pull up, push over, release, confirm release and turn. By the time you have done all that the thermal is far behind you and your chances of finding it are poor. The only value for reduced tension release is to protect poorly designed glider tow hooks. Like many things you learn in 2-33's it should be discarded when you fly a sailplane. Andy |
I think Gary is right on on this.
Normal tension on the rope during tow for a 2-33 is about 50 pounds. This will not damage anything. The problem is that instructors commonly fail to teach releasing in a steady state situation and many students begin to learn to anticipate the release and start to pull up before releasing. This is where the big bangs come from. Tow pilots HATE soft releases because they only then know release has occurred by subtle trim change(if in high tow) or mirror. With normal release tuggie feels slight shake at release, visually confirms, and gets out of Dodge. UH |
Actully Andy has it right. The soft release genisis
is from a poorly designed tow hook....and a service bulletin from Scheweizer. The 2-33 is not a good example of the gliders most of us fly today. So I would not use this method unless I was flying the glider that has the service bulletin to comply with. Now I have seen the soft release go to a 'winch pull' then push over. It makes me a bit nervous when a glider pitchs up like that. The only value for reduced tension release is to protect poorly designed glider tow hooks. Like many things you learn in 2-33's it should be discarded when you fly a sailplane. Andy Jeff Banks |
Gary Boggs wrote:
I'm not sure about the rest of the world, but here in the USA it's pretty wide spread to release the tension on the tow rope before pulling the release handle by getting a little high, and then doing a shallow dive. If I remember right, this came about because the tow hooks on the Schweizers were swinging forward, beating themselves to pieces when pulled with a lot of tension on the line. I think this maneuver is no longer necessary because the tow hooks on the Schweizers were modified with a friction device in the slot in front of the arm that cushions the arm as it swings forward, but the practice is now standard in many places. It may be a good idea in theory, but the reality of the situation is that this is not an easy thing to do for a lot of pilots. There are many pilots that pull up too far, and then actually overtake the rope before pulling the release, so that now the end of the line is dangling somewhere along side the ship. I sounds like an easy maneuver, but in my opinion, it's more dangerous than it's worth. I think the practice of attempting a soft release should be eliminated. In my opinion, pulling the release with tension on it is much safer. I think undoing the occasional knot in the rope is far safer than the possibility of getting tangled in the end of the rope. Is this practice used anywhere else in the world? Please give me some feedback. Ask a thousand people, and you'll get a thousand answers. Here's my view. Any certificated pilots should have the skills to execute either a normal or a soft release. If someone damages an aircraft because of an improper soft release, they really need to spend some more time getting instruction. That said, I've flown with several instructors. Most claim you should always do soft releases on Schweitzers, and do soft or normal releases on Tost hooks. I believe Schweitzer says you should always do soft releases on their tow hooks. However, I have flown with one instructor who adamantly insists that normal releases put unneccessary excessive stress on the aircraft structure and should be avoided on all aircraft, regardless of tow hook. I've also flown with another instructor (who is also an IA) who insists that you should always perform normal releases on all aircraft (regardless of tow hook). He claims that he is unconvinced that a normal release will do damage to even a Schweitzer release, and I think he is uncomfortable with the concept of a soft release because it lacks the positive confirmation that release has actually occurred. I rarely ever fly Schweitzers, and I typically will practice both release styles. If I am flying a Schweitzer, I do soft releases. If I'm flying with an instructor I will always ask them which they want me to perform. dan |
notme wrote:
Any certificated pilots should have the skills to execute either a normal or a soft release. (an) instructor...insists that you...perform normal releases on all aircraft...and I think he is uncomfortable with the concept of a soft release because it lacks the positive confirmation that release has actually occurred. _Positive_ confirmation is seeing the rope fall away from the glider, and it works for any release, soft or hard. As a tow pilot I prefer a normal release, and a glider pilot who gains separation after release with an obvious, but not a dramatic, maneuver. No rush, no mistakes, no confusion, no frightening the tug driver. Jack |
![]() "Jack" wrote in message news ![]() _Positive_ confirmation is seeing the rope fall away from the glider, and it works for any release, soft or hard. Unfortunately, not true; at least not in all gliders. Especially not true if you are a back seater. When I do a soft release, gravity pulls the ring down out of sight and I either have to gently maneuver away from the ring or sit there and wait for it to finally come into view. Vaughn |
Vaughn wrote:
_Positive_ confirmation is seeing the rope fall away from the glider, and it works for any release, soft or hard. Unfortunately, not true; at least not in all gliders. Especially not true if you are a back seater. Ah, the vision thing.... I've found that one can use use elevator and rudder, gently, as you suggest, to make all things clear from either seat. I am increasingly reluctant, as the years progress, to beat up the tow hooks on the Schweizers I fly by using a hard release. I prefer a modified-soft, if you will; tension reduced (no slack line) and visual confirmation of separation. Something more straight forward might be better when working with students. As a tow pilot I want no doubt at either end that there is a confirmed release. Neither of us would enjoy the Nantucket Sleigh Ride that can result from a miscue. Jack |
Forgive my ignorance, I am speaking from the UK and we don't generally
see Schweizers in this country, but can you change the hooks to something similar to everything else, say a Tost hook? Then you would get the same release characteristics as all other gliders. Robin In message , Jack writes Vaughn wrote: _Positive_ confirmation is seeing the rope fall away from the glider, and it works for any release, soft or hard. Unfortunately, not true; at least not in all gliders. Especially not true if you are a back seater. Ah, the vision thing.... I've found that one can use use elevator and rudder, gently, as you suggest, to make all things clear from either seat. I am increasingly reluctant, as the years progress, to beat up the tow hooks on the Schweizers I fly by using a hard release. I prefer a modified-soft, if you will; tension reduced (no slack line) and visual confirmation of separation. Something more straight forward might be better when working with students. As a tow pilot I want no doubt at either end that there is a confirmed release. Neither of us would enjoy the Nantucket Sleigh Ride that can result from a miscue. Jack -- Robin Birch |
As far as I know it isn't used in the UK as just about everybody has
Tost, or in a small number of cases Otfur type hooks. As a result we are taught to NOT overtake the rings. Essentially you fly normally and release, as soon as you can see the rings go clear then gently pull back to burn off some speed and increase the separation distance as rapidly as possible. Robin In message , Gary Boggs writes I'm not sure about the rest of the world, but here in the USA it's pretty wide spread to release the tension on the tow rope before pulling the release handle by getting a little high, and then doing a shallow dive. If I remember right, this came about because the tow hooks on the Schweizers were swinging forward, beating themselves to pieces when pulled with a lot of tension on the line. I think this maneuver is no longer necessary because the tow hooks on the Schweizers were modified with a friction device in the slot in front of the arm that cushions the arm as it swings forward, but the practice is now standard in many places. It may be a good idea in theory, but the reality of the situation is that this is not an easy thing to do for a lot of pilots. There are many pilots that pull up too far, and then actually overtake the rope before pulling the release, so that now the end of the line is dangling somewhere along side the ship. I sounds like an easy maneuver, but in my opinion, it's more dangerous than it's worth. I think the practice of attempting a soft release should be eliminated. In my opinion, pulling the release with tension on it is much safer. I think undoing the occasional knot in the rope is far safer than the possibility of getting tangled in the end of the rope. Is this practice used anywhere else in the world? Please give me some feedback. Gary Boggs -- Robin Birch |
FL 2004 - Brakes will not release | James | Simulators | 3 | March 27th 05 03:23 AM |
Twin Lark - CG release | Mark Zivley | Soaring | 7 | August 17th 04 04:20 PM |
Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 2nd 04 11:15 PM |
Air Force Museum Working Group to release final report | Otis Willie | Military Aviation | 0 | November 18th 03 12:28 AM |
ANN: flyWithCE news release - November 2003 | Uros Podlogar | Soaring | 0 | November 16th 03 09:23 AM |
