Motor Glider clean up
Old February 14th 06, 04:05 AM posted to rec.aviation.soaring
Default Motor Glider clean up
I use a product called Power Foam, made by Jetstream
Products. It is the ONLY thing I have found that removes
the pyro smoke residue from my wingtips. It also does
a great job of removing jet exhaust residue. Their
Flyer's Speed wax does a pretty fair job as well.
All are approved for airline use.
http://www.jetstreamproducts.com/
Bob C.
At 17:54 13 February 2006, Bumper wrote:
Bob,
The original formula 'Go-Jo' hand cleaner (without
pumice!) works well on
the Mooney and Husky belly. Just wipe on by hand and
then off with a clean
cloth.
Being aware of the problems with many cleaners (409
and even Simple Green),
I tested Go-Jo to be sure it has no unintended negative
impact on aluminum.
To do this, I submerged and partially submerged aluminum
test strips in the
cleaner for several weeks. No staining or corrosion
noted.
Added advantage of Go-Jo is it easily removes 100LL
exhaust residue,
something many of the usual cleaners don't do so well.
Have not found the need to do this on the ASH26E, as
the engine seems
housebroken and doesn't make a mess.
bumper
'Bob Caldwell' wrote in
message ...
Hi Pilots,
What is the best cleaning product(s) for cleaning
up the tailplane and
areas behind the engine after operation? I need something
that cuts
grease and oil better than Wx Block I but will be
kind to the gelcoat.
What combination of cleaners and conditioners work
best? Suggestions?
Thanks,
Bob Caldwell
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 03:09 AM
Beware Super Clean Jay Honeck Owning 35 July 19th 04 03:27 PM
Need suggestions for clean butt splice for electrical wires. Bart D. Hull Home Built 9 January 30th 04 04:28 AM
Very Clean Fil330 General Aviation 0 October 29th 03 11:53 AM
Need clean 1-26E canopy frame Robert de León Soaring 0 July 22nd 03 07:16 PM
