#11
pbc76049 wrote:
Hi Ron. I wouldn't say the standard is OA. That would mean there IS a standard, and there isn't one. The entire center wing box of the B1 is welded Titanium, and not a gas weld to be seen. Light alloy steel tubular structures are almost universally welded with an electric process with the exception of low dollar lugged bicycle frames which are brazed. Nascar Roll Cage rules prohibit TIG welded joints due to some history of brittle failures in what should be a deformable structure. Their preferred process is MIG. Very few aluminum fabricators use torches anymore, their preferred process is TIG. Homebuilders use OA gear because it is cheap to use, requires a low degree of skill to get acceptable results, and is portable. You might wish to go to the welding specs and do a bit of review. The SAE and AWS do not require/recommend PWHT of 4130 welds on material less than 1/2 inch thick. PWHT of 4130 only adds to its ability to move to somewhere you don't want it . Post weld heat treatment can do more harm thru distortion than any small benefit you MIGHT get reheating things. Some further information... Bud Davisson's How To Get Started in Homebuilding articles: http://www.airbum.com/articles.html#How Zen and the Weld Puddle: http://www.airbum.com/articles/ArticleZenWelding.html Richard |
Rag and tube construction and computer models? | BllFs6 | Home Built | 24 | April 12th 04 12:20 PM |
Why 4130 tube? | Leon McAtee | Home Built | 31 | March 28th 04 03:04 PM |
Driving sheet-metal screws into 4130 | Grandpa B. | Home Built | 10 | February 3rd 04 07:23 PM |
TIG welding video? | Russell Duffy | Home Built | 3 | October 6th 03 05:55 AM |
Welding techniques for 4130? | Building The Perfect Beast | Home Built | 29 | September 4th 03 08:52 PM |
