Ron Rosenfeld wrote in message . ..
On 20 May 2004 23:13:28 -0700, (Doug) wrote: So I am in the hold at the BJC VOR for the VOR DME approach to 2v2. http://www.naco.faa.gov/d-tpp/0405/09041VDA.PDF At what point do I leave the hold and intercept the 345 radial? I think the reason that there all these answers is that it does not matter. The commentator who said make all turns on the holding pattern side gave accurate guidance. Look at the terrain and guess why they put the hold on the east side. There are a lot of miles between the holding fix and the faf. And all of it is clear for you. So getting established can't be much of a factor. I'd turn most directly to intercept 345 inbound from wherever in the hold I got the approach clearance. Maneuvering south of Jeffco seems to be specifically prohibited by the remark. Since you don't get to review every decision on the internet while flying the approach, wisest is to confer with ATC over what you are going to do when in doubt. Regards, Bill Hale -- who used to be based at 2v2 when you shot the ils into FNL then scud ran over KLMO broadcast station and let down into 2v2. -- not a charted procedure... |
![]() Bill Hale wrote: Since you don't get to review every decision on the internet while flying the approach, wisest is to confer with ATC over what you are going to do when in doubt. ATC separates aircraft; they don't interpret instrument procedures. Something is lacking in some pilots training to not understand the ideal is to treat major course changes as flyby waypoints, not flyover waypoints. The only flyover waypoint is a charted flyover waypoint; and there aren't any of those on VOR approaches. |
ideal is to treat major course changes as flyby waypoints, not flyover waypoints. This goes back to a question I had a while back about "Complete Reversal." To me the question is how to give a student a criteria for leading turns on an instrument approach. I can't tell from TERPS whether this was ever intended; it does suggest that the framers assumed that navaids would be flown over, rather than by. The AIM says to lead turns on airways, but I have found no FAA justification to lead turns on instrument approaches. So the questions arise: 1) is it *always* safe to lead turns?, 2) is it *legal*?, and 3) will it pass checkrides? |
Greg Esres wrote:
To me the question is how to give a student a criteria for leading turns on an instrument approach. I can't tell from TERPS whether this was ever intended; it does suggest that the framers assumed that navaids would be flown over, rather than by. I think that assumption was based on how most navaids work. You don't really know you're over a VOR until you get a full TO/FROM flip. Even with DME, slant range makes it pretty difficult to calculate leads for turns. You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, your true airspeed is 170 kts, you've got a 30 kt left-quartering tailwind, and you need to make a 70 degree turn to the right; quick, at what DME readout should you start your turn? The GPS I fly with works all those numbers (OK, it doesn't know the wind, but it does know my groundspeed, and uses horizontal distance instead of slant), gives me an audible "boing" and a 10-second countdown to "turn now", and if I zoom the map in far enough, even draws me a nice magenta curved line on the screen to follow. |
![]() "Roy Smith" wrote in message ... You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, Lousy guess, field elevation at BJC is 6012 or thereabouts. |
![]() "Roy Smith" wrote in message ... You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, your true airspeed is 170 kts, you've got a 30 kt left-quartering tailwind, and you need to make a 70 degree turn to the right; quick, at what DME readout should you start your turn? VOR site elevations are published in the Airport/Facility Directory. Elevation at BJC VOR/DME is 5734 MSL. |
Oh, no doubt. One might be led to think that there is more protected area on the other side (where you overshoot the navaid) than on the side from which you're approaching. I vaguely recall seeing that was true in the enoute segment in certain circumstances (don't hold me to this), but was NOT true in the approach segment. at what DME readout should you start your turn? Exactly. And even if *I* could do it, can I expect a student to be as proficient at it or understand the nuances as to when it should be applied? An instrument pilot shouldn't have to be a TERPS expert to fly safely. I think it more prudent to hand a student a set of simple rules that will always work, which is why I'm uncomfortable recommending leading turns on non-GPS approaches. I think it's OK, but I can't *prove* it. The GPS I fly with works all those numbers (OK, it doesn't know the With GPS, different story. I presume that following any lead provided is both safe and legal. |
![]() 1) is it *always* safe to lead turns?, 2) is it *legal*?, and 3) will it pass checkrides? Nothing is "always" safe. However, if when you lead the turn you are within the positional tolerance of both the initial and final courses, yes, I think it's safe (and preferred). I know of no rule that makes it illegal to do so Whether it passes checkrides depends on whether the check pilot has the same take on it. Jose -- (for Email, make the obvious changes in my address) |
Screw hold repair in fabric? | Brian Huffaker | Home Built | 11 | May 29th 04 02:07 AM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
Need Hold Harmless Waver for Ultralight or Experimental Sale | Larry Smith | Home Built | 9 | August 19th 03 02:47 AM |
Need a Waiver/ Hold Harmless Agreement for UL / Experimental Sale | Richard_Tonry | Home Built | 2 | August 17th 03 12:58 PM |
