Newps wrote:
"Matt Whiting" wrote in message ... I suspect it has to do with the location of the antenna. I don't they they are all located in exactly the same spot WRT to the runway. The glideslopes are as they are all positioned to bring you to the same spot on every runway. The localizer is sited so it is a certain width at the approach end of the runway, therefore they will move the localizer antenna closer to or farther away from the departure end of the runway to achieve that. Then why do some runways have ILS critical areas and others do not? Matt |
![]() "Matt Whiting" wrote in message ... Then why do some runways have ILS critical areas and others do not? All runways have an ILS critical area. The issue is whether there is a taxiway that passes through it or not. |
![]() "Ron Natalie" wrote in message . .. All runways have an ILS critical area. Actually, it's just those with an ILS. And runways with a full ILS have two critical areas, a Localizer Critical Area and a Glideslope Critical Area. The issue is whether there is a taxiway that passes through it or not. To help illustrate this I've posted two figures from FAA Order 6750.16, "Siting Criteria for Instrument Landing Systems", in alt.binaries.pictures.aviation. The subject is ILS Critical Areas. |
Ron Natalie wrote:
"Matt Whiting" wrote in message ... Then why do some runways have ILS critical areas and others do not? All runways have an ILS critical area. The issue is whether there is a taxiway that passes through it or not. My home airport, N38, doesn't. :-) Matt |
The longer runways are more likely to have critical areas. Runways whose
taxiways get too close to the runway is also a factor. We have that problem here at BIL. The last 3000 feet of taxiway angles in toward the runway creating the need for an ILS hold area because you get in the way of the localizer. "Matt Whiting" wrote in message ... Newps wrote: "Matt Whiting" wrote in message ... I suspect it has to do with the location of the antenna. I don't they they are all located in exactly the same spot WRT to the runway. The glideslopes are as they are all positioned to bring you to the same spot on every runway. The localizer is sited so it is a certain width at the approach end of the runway, therefore they will move the localizer antenna closer to or farther away from the departure end of the runway to achieve that. Then why do some runways have ILS critical areas and others do not? Matt |
Why? Jose -- (for Email, make the obvious changes in my address) |
Teacherjh wrote:
The longer runways are more likely to have critical areas. Why? The localizer will be closer to the (opposite) runway threshold. All the best, David |
In article
ogers.com, David Megginson wrote: Teacherjh wrote: The longer runways are more likely to have critical areas. Why? The localizer will be closer to the (opposite) runway threshold. All the best, David Why should runway length affect how far the localizer antenna is from the runway end? Localizers are designed to have a fixed width (something like 700 ft lateral displacement for full-scale deflection on the CDI) at the arrival threshold, so longer runways will have narrower angular beam widths. But (to the best of my knowledge) this is done by adjusting the spacing of the transmitting elements on the localizer array, not by adjusting the distance of the array from the runway end. |
![]() Localizers are designed to have a fixed width (something like 700 ft lateral displacement for full-scale deflection on the CDI) at the arrival threshold, so longer runways will have narrower angular beam widths. Doesn't make sense to me. Angular beam width should be constant - for the far field. Then the antenna is placed at the distance from the arrival end (also constant) that gives the proper width. No? Jose -- (for Email, make the obvious changes in my address) |
![]() "David Megginson" wrote in message le.rogers.com... The localizer will be closer to the (opposite) runway threshold. So what? |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
CAD outline of Rans S6S instrument panel? | Rob Turk | Home Built | 2 | October 21st 03 09:27 PM |
