Greg Esres wrote:
To me the question is how to give a student a criteria for leading turns on an instrument approach. I can't tell from TERPS whether this was ever intended; it does suggest that the framers assumed that navaids would be flown over, rather than by. I think that assumption was based on how most navaids work. You don't really know you're over a VOR until you get a full TO/FROM flip. Even with DME, slant range makes it pretty difficult to calculate leads for turns. You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, your true airspeed is 170 kts, you've got a 30 kt left-quartering tailwind, and you need to make a 70 degree turn to the right; quick, at what DME readout should you start your turn? The GPS I fly with works all those numbers (OK, it doesn't know the wind, but it does know my groundspeed, and uses horizontal distance instead of slant), gives me an audible "boing" and a 10-second countdown to "turn now", and if I zoom the map in far enough, even draws me a nice magenta curved line on the screen to follow. |
![]() "Roy Smith" wrote in message ... You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, Lousy guess, field elevation at BJC is 6012 or thereabouts. |
![]() "Roy Smith" wrote in message ... You're at 9000 MSL, the elevation of the VORTAC isn't even published, but you can guess it's about 1000 MSL, your true airspeed is 170 kts, you've got a 30 kt left-quartering tailwind, and you need to make a 70 degree turn to the right; quick, at what DME readout should you start your turn? VOR site elevations are published in the Airport/Facility Directory. Elevation at BJC VOR/DME is 5734 MSL. |
Oh, no doubt. One might be led to think that there is more protected area on the other side (where you overshoot the navaid) than on the side from which you're approaching. I vaguely recall seeing that was true in the enoute segment in certain circumstances (don't hold me to this), but was NOT true in the approach segment. at what DME readout should you start your turn? Exactly. And even if *I* could do it, can I expect a student to be as proficient at it or understand the nuances as to when it should be applied? An instrument pilot shouldn't have to be a TERPS expert to fly safely. I think it more prudent to hand a student a set of simple rules that will always work, which is why I'm uncomfortable recommending leading turns on non-GPS approaches. I think it's OK, but I can't *prove* it. The GPS I fly with works all those numbers (OK, it doesn't know the With GPS, different story. I presume that following any lead provided is both safe and legal. |
Screw hold repair in fabric? | Brian Huffaker | Home Built | 11 | May 29th 04 02:07 AM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
Need Hold Harmless Waver for Ultralight or Experimental Sale | Larry Smith | Home Built | 9 | August 19th 03 02:47 AM |
Need a Waiver/ Hold Harmless Agreement for UL / Experimental Sale | Richard_Tonry | Home Built | 2 | August 17th 03 12:58 PM |
