question on student taxi practice
Old April 7th 06, 04:29 AM posted to rec.aviation.piloting,rec.aviation.student
Default question on student taxi practice
"Jose" wrote in message
om...
if the student is not ready to fly solo, he is not ready to taxi solo.
I disagree. Actually flying an airplane, keeping it within its aviation
envelope and reacting properly and swiftly should the aircraft approach
the edge of its envelope, making a smooth approach to the runway at the
proper speed, arriving sufficiently close to the desired touchdown point,
arresting the descent smoothly and touching down gently enough to reuse
the aircraft, and maintaining directional control on the ground at close
to flying speed requires significantly more skill than taxiing on the
ground, especially in a nosewheel.
Jose
This might not be the best analogy to make for this issue Jose. Naturally it
takes more ability to accomplish all of these things than just the one skill
of taxiing the aircraft on the ground. That isn't the issues here. The issue
is instructor judgment.
An accident is an accident whether it happens in the air or on the ground.
It happens in aviation that one can easily kill someone with an airplane on
the ground. Also, as I have stated in another post, there is the issue of
responsibility transition as that applies to sound instruction procedure.
Making a case for allowing a 2 hour student to taxi an airplane unsupervised
is something you might want to revisit. Of course this is only my opinion. I
can only say that I wouldn't have hired any instructor to work for me who
would make this case.
Dudley Henriques
Old April 7th 06, 05:03 PM posted to rec.aviation.piloting,rec.aviation.student
is instructor judgment. [...]
Well, all we know about the pilot is that he is a "two hour student",
which doesn't say much. The same argument you made could be made for
IFR flight - allowing a ten hour student to fly an airplane all by
himself, through the air, and a hundred miles an hour, even though he is
not ready to fly in instrument conditions. The issue =there= is also
instructor judgement. However, the lack of instrument experience has no
bearing if the student is not going to fly on instruments. Likewise,
the (presumed) lack of ability to fly through the air safely and land
gently has no bearing if the student is only going to taxi at ten knots
with a nosewheel.
Instructor judgement would include this.
Jose
Nothing takes longer than a shortcut.
Old April 8th 06, 12:48 AM posted to rec.aviation.piloting,rec.aviation.student
You and I are so diametrically opposed in our opinions on how to conduct
flight instruction that at this point I think I'll just hope we can agree to
disagree and bid each other a friendly goodbye :-)
Dudley Henriques
That isn't the issues here. The issue is instructor judgment. [...]
unsupervised is something you might want to revisit.
which doesn't say much. The same argument you made could be made for IFR
flight - allowing a ten hour student to fly an airplane all by himself,
through the air, and a hundred miles an hour, even though he is not ready
to fly in instrument conditions. The issue =there= is also instructor
judgement. However, the lack of instrument experience has no bearing if
the student is not going to fly on instruments. Likewise, the (presumed)
lack of ability to fly through the air safely and land gently has no
bearing if the student is only going to taxi at ten knots with a
nosewheel.
Jose
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
