#11
Dave S wrote:
Sometime shortly after the catalytic converters were mandated, heat shields were also mandated that are _supposed_ to prevent this fire problem.... The heat shield cuts down on radiant heat from the CC, but if the heatshield itself is hot enough and TOUCHES the tall dry grass, then you still have a fire. Seems like if there's ANY air gap at all between the CC and shield that there would be a HUGE difference in temperature between the two. If there's no air gap, then it's not a shield, really. Mark Hickey |
![]() Mark Hickey wrote: Dave S wrote: Sometime shortly after the catalytic converters were mandated, heat shields were also mandated that are _supposed_ to prevent this fire problem.... The heat shield cuts down on radiant heat from the CC, but if the heatshield itself is hot enough and TOUCHES the tall dry grass, then you still have a fire. Seems like if there's ANY air gap at all between the CC and shield that there would be a HUGE difference in temperature between the two. If there's no air gap, then it's not a shield, really. I'd worry that tall grass could get caught and wadded between the two while driving. -- FF |
wrote)
I'd worry that tall grass could get caught and wadded between the two while driving. During the Minnesota Twins World Series parade, in 1987, a few of the convertibles caught fire from just that - paper, toilet paper, confetti, etc. dragged along under the cars. In 1991 the players sat/stood in the beds of 4x4 pickup trucks. Montblack |
Shoot, Uncle John, I don't know how things are up north of us by you, but in
Northern California you couldn't light the grass on fire with a propane torch and a tank full of gasoline. 83" of rain so far this year, and still pounding down. I just talked with a guest who is coming in from NorCal, and he says the flying there has absolutely SUCKED for the last five months. Very unusual. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Thats kinda reminds me how I disposed of some old gunpowder. Dumped it
in the outdoor fireplace and touched it off. The flame built up slowly, but it eventually had a flame about 10' high the diameter of the pile of powder. Very impressive, but too expensive to repeat! ![]() John |
John T wrote:
Thats kinda reminds me how I disposed of some old gunpowder. Dumped it in the outdoor fireplace and touched it off. The flame built up slowly, but it eventually had a flame about 10' high the diameter of the pile of powder. Very impressive, but too expensive to repeat! ![]() John That's smokeless powder, try it with black powder ![]() experiment: put a tablespoonful of black powder in an ash tray. Touch it off with a blowtorch held at arm's length. The powder will burn fast enough to extinguish the blowtorch. Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message news:bwZZf.362$iF3.333@dukeread01... John T wrote: Thats kinda reminds me how I disposed of some old gunpowder. Dumped it in the outdoor fireplace and touched it off. The flame built up slowly, but it eventually had a flame about 10' high the diameter of the pile of powder. Very impressive, but too expensive to repeat! ![]() John That's smokeless powder, try it with black powder ![]() experiment: put a tablespoonful of black powder in an ash tray. Touch it off with a blowtorch held at arm's length. The powder will burn fast enough to extinguish the blowtorch. Dan, U.S. Air Force, retired I sure hope that you meant demonstration rather than experiment; because I'd be way too scared to try anything like that on an experimental basis. Peter BTW, the USAF must have been an entertaining place. :-) |
Dan wrote:
John T wrote: Thats kinda reminds me how I disposed of some old gunpowder. Dumped it in the outdoor fireplace and touched it off. The flame built up slowly, but it eventually had a flame about 10' high the diameter of the pile of powder. Very impressive, but too expensive to repeat! ![]() John That's smokeless powder, try it with black powder ![]() experiment: put a tablespoonful of black powder in an ash tray. Touch it off with a blowtorch held at arm's length. The powder will burn fast enough to extinguish the blowtorch. Dan, U.S. Air Force, retired |
On Sat, 08 Apr 2006 13:24:55 GMT, Dave S
wrote: Sometime shortly after the catalytic converters were mandated, heat shields were also mandated that are _supposed_ to prevent this fire problem.... The heat shield cuts down on radiant heat from the CC, but if the heatshield itself is hot enough and TOUCHES the tall dry grass, then you still have a fire. Dave And any mechanic knows the heat sheilds often do not last more than a few years before they come loose and rattle. Then they can either be clamped on, welded on, or allowed (or helped) to fall off. A minor missfire can also cause the converter to overheat. Imagine what happens if the engine "diesels" on shut-down. My wife drove our Corolla to visit her family in Windsor, and the cruise stuck, holding the throttle partly open. When she shut it off(in neutral) it "dieseled" and the cat must have flashed white hot, as it caused the carpet on the floor above the converter to start on fire. The carpet, a corner of the seat, and the console had been consumed by the smokey fire before her sisterinlaw and nephew got the hose out and turned on. We salvaged the car and got a few more years out of it, but if IT had been on dry grass on a breezy day, that would have been the end of it. *** Free account sponsored by SecureIX.com *** *** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com *** |
![]() clare at snyder.on.ca wrote A minor missfire can also cause the converter to overheat. Imagine what happens if the engine "diesels" on shut-down. We salvaged the car and got a few more years out of it, but if IT had been on dry grass on a breezy day, that would have been the end of it. Yep. I had an Olds that was suddenly having intermittent loss of almost all power, then it would be fine. I was driving it one day and hit a bump, and heard a strange "ker-thump" (that's technical car talk g) then it lost all power. Long to short, I started thinking about the 'ole potato in the tailpipe, and how it behaved like that. I cut into the pipe downstream of the converter, and saw that all of the pellets had melted into a perfectly molded lump, just the shape of the back part of the cat. shell. When I hit the bump, the lump rolled into the outlet, and shut off the exhaust gas flow. Really lucky to trouble shoot that one! It is hard to say how hot it had gotten to melt the pellets, like that. Certainly hot enough to start a fire. -- Jim in NC |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
"Friendly fire" | Mike | Naval Aviation | 3 | April 6th 04 06:07 PM |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
"Friendly fire" | Mike | Military Aviation | 0 | March 19th 04 02:36 PM |
