Jepp no longer in the GA business...?
Old June 11th 04, 07:53 PM
Roy Smith wrote:
Good point. Is there any easy way for the general public to access
notams other than through duats? Duats is OK for human use, but it's a
pain if you're trying to automate anything.
I don't know of any automated method. But, one of the DUAT vendors, I don't recall
which one off-hand, makes it pretty easy by requesting a single location briefing
and including FDC NOTAMs specific to that location. It you err and include general
FDC NOTAMs you end up with all that mostly useless BS.
One of the problems with FDC notams is there's so much volume, and so
little of it is actually relevant to any flight. It would be nice to
have a system that let you tick of which airports you were interested
in, and it would just gather up the approach plate PDFs and find any
associated FDC notams automatically.
I suppose I've been living dangerously, but I havn't looked at an AFD in
years. When I was a Jepp user, the added info came with the Jepp kit.
Now, I find that I get everything I need to know about an airport from
one or another web site. I can't remember the last time I got someplace
and didn't know something I needed to know in advance.
Give your method a test. Check both Runway 3 at PHLI (Lihue, Hawaii) and Runway 15
at KASE (Aspen, Colorado) and see if you get the VGSI restrictions for both of
those runways. If you do, you likely don't need the AF/D either.
Neither AOPA's nor Aeroplanner airport directories for those two airports provide
that information.
Old June 11th 04, 08:57 PM
Dave Butler
Did you mean PLIH? What's VGSI? If I didn't get the VGSI restrictions for an
airport, I wouldn't even know what I didn't have.
Dave
Old June 12th 04, 02:39 AM
Matt Whiting
and Runway 15
both of
for an airport, I wouldn't even know what I didn't have.
Dave
I hadn't heard the term either, but according to this article
(http://www.jeppesen.com/download/aopa/nov99aopa.pdf)
it is just a new term for VASI or PAPI.
Matt
Old June 12th 04, 03:17 PM
Dave
PHLI is Lihue, Hawaii, the main airport on Kauai. The domestic identifier is LIH. VGSI
(visual glide slope indicator) is the generic term for PAPI or VASI.
From the AIM:
"Pilots should be aware that the published angle is for information only - it is strictly
advisory in nature. There is no implicit additional obstacle protection below the MDA.
Pilots must still respect the published minimum descent altitude (MDA) unless the visual
cues stated in 14 CFR Section 91.175 are present. In rare cases, the published procedure
descent angle will not coincide with the Visual Glide Slope Indicator (VGSI); VASI or
PAPI. In these cases, the procedure will be annotated: 'VGSI and descent angle not
coincident.' "
Old June 12th 04, 04:31 PM
Stan Prevost
wrote in message ...
briefing
include general
DTC DUAT has that feature. However, it has pitfalls.
You must know the identifier to use to get NOTAMs, and it is not always the
airport identifier. For example, a nearby (to me) airport 5M0 has an
instrument approach but no weather reporting. If you use the "Specific
Location" feature of DUAT with identifier 5M0 in an attempt to find NOTAMs
for that airport, you will get an error message that it is not a valid
weather reporting identifier. The way around this is to use the identifier
lookup feature on the Specific Location page (the binoculars over the
"Location ID" box). Enter the airport identifier (or name) into the lookup
dialog box and you will get a response that gives you the identifier to use
to get NOTAMs. It will usually be the AFSS serving that airport if there is
no weather reporting from that airport. For 5M0 NOTAMS, I would use ANB as
the identifier in the "Specific Locations" Location ID box.
Seems like the software ought to look up the proper ID for NOTAMS and use
that. I discussed this at length with the DTC folks at Oskosh last year,
and once they understood the confusing aspect of this for someone just
wanting to look up NOTAM info, they seemed interested in changing it. But
so far, nothing.
Another problem is that even when you enter the correct ID to get NOTAMs for
a specific airport, there may be no NOTAMs for that airport, but you will
still get a long list of NOTAMs for navaids, GPS, LORAN, and airports
hundreds of miles away, even selecting just NOTAMs and FDC NOTAMs,
deselecting General FDC NOTAMs and everything else. You have to use your
browser text search feature to see if there is anything for the airport of
interest embedded in that long list.
Stan
Jepp vs NOS at PRB Doug Campbell Instrument Flight Rules 47 May 6th 04 06:40 PM
Airport Radial/Distance/Fix on Jepp Airport Chart Dave Johnson Instrument Flight Rules 9 May 3rd 04 12:03 AM
JEPP Chart Users Ross Richardson Instrument Flight Rules 6 March 29th 04 11:58 PM
who moved SAV, forgot to tell Jepp? Dave Butler Instrument Flight Rules 15 November 9th 03 03:16 AM
Jepp Charts - Subscription Only? Peter Gibbons Instrument Flight Rules 8 November 8th 03 03:01 PM
