Same problem on many Cessna high-wing singles. They have tried to place
the little, forward-facing vent just behind the strut, to minimize the slight static pressure that develops in flight, but you'll still have a faster draw from one side. In my experience, newer models are no better. There are literally dozens of articles on the subject, and as many proposals for fixes. Some of these are probably good, and you should do some internet research if this is bothering you. My own fix is simply to switch to right tank only once I'm in cruise, and manage the disparity from there. Back to both, of course, in the pre-land checklist. GF |
Check the fuel tank cap seals. On that airplane they have
O-rings that are supposed to be checked yearly (there's an AD on it) to prevent leaks, both water in and air out. The O-rings get old, hard, and cracked. A leak on the right side will create a slightly lower pressure that on the left, and the left tank will drain faster. A big enough leak will suck a lot of fuel out of the tank and collapse the bladder. Cessna sells a kit to replace those caps with the style we see on the 172, minimizing the problem. We run three Cessna 172s, an R182 and two Citabrias, all with the same venting system, and as long as we keep the seals tight the fuel drains evenly. As soon as a cap develops a leak the uneven drainage shows up. The vent under the left wing bothers some people, as they think the left tank gets more pressure than the right, but if things are otherwise sealed the pressures are equal in both tanks (Boyle's Law) and uneven drainage is more likely due to restrictions in the fuel lines. When the tanks are full or near full there's some fuel movement between tanks (left to right) through the vent interconnect, but certainly not 3/4 of a tank's worth. The fuel cap AD: http://www.airweb.faa.gov/Regulatory...C?OpenDocument AOPA's take on the 182 uneven fuel feeding: http://www.cessna.org/store/buyers_g..._excerpts.html AN exceprt from that excellent article: "This condition can be minimized somewhat by adjusting the position of the fuel vent behind the lift strut on the left wing, making sure that fuel caps seal tightly so that the "head pressure" in one tank is not altered by a leaking cap..." Dan |
Starting new C172s | navghtivs | Piloting | 76 | September 10th 05 09:33 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Mandatory SB565 Lycoming fuel pump | Paul kgyy | Owning | 18 | March 22nd 05 03:22 PM |
Most experienced CFI runs out of gas | Robert M. Gary | Piloting | 54 | November 19th 04 01:24 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
