Richard,
What you are seeing is normal. You will see many so called "fixes", but none of them address the fact that most Cessnas have done this forever, even brand new, and will continue to. I have ferried many new Cessnas from Wichita and they all did the same thing, including a gorgeous A185E I bought new for myself. If it bothers you or you get a heavy wing in flight just switch to the fuller tank for a while. I've never heard of a Cessna running out of fuel when "both" is selected and there was usable fuel in one wing . That's not to say that you might not actually have a problem, like a blockage in a vent line or something. I'm just saying that if you have it checked out and they find nothing, don't worry. Best, Karl ATP, CFI, ETC. "Curator" N185KG "Richard Ross" wrote in message ... Has anyone heard of a problem in earlier (1974) C182s where one fuel tank will draw down 3/4 before drawing from other tank when fuel selector in "Both" position? If so, any articles online? Richard |
That problem is present on a 1986 'R' model that I fly, the FBO guy at a
nearby airport always comments on it when I stop by for cheap(er) fuel. -- Hello, my name is Mike, and I am an airplane addict... |
"Michael Ware" wrote: That problem is present on a 1986 'R' model that I fly, the FBO guy at a nearby airport always comments on it when I stop by for cheap(er) fuel. The 182R and 182S that I fly have the same habit. |
On Thu, 27 Apr 2006 08:57:11 -0700, karl gruber wrote:
f it bothers you or you get a heavy wing in flight just switch to the fuller tank for a while. In either an R182 (1979) or 182Q (1980) (I cannot recall in which I did this test), switching to the most full tank doesn't have the effect one hopes. It still seems to draw more from the "wrong" tank (although in fact it's probably drawing from the selected tank with fuel moving through the interconnect to replace the drawn fuel). The CPA tech note only refers to pre-1979 models. This may be of great value to the OP and his 1974 182, but many of us are apparently experiencing at least similar problems in models of 1979 and beyond. - Andrew |
![]() "Andrew Gideon" wrote in message news ![]() On Thu, 27 Apr 2006 08:57:11 -0700, karl gruber wrote: f it bothers you or you get a heavy wing in flight just switch to the fuller tank for a while. In either an R182 (1979) or 182Q (1980) (I cannot recall in which I did this test), switching to the most full tank doesn't have the effect one hopes. It still seems to draw more from the "wrong" tank (although in fact it's probably drawing from the selected tank with fuel moving through the interconnect to replace the drawn fuel). The CPA tech note only refers to pre-1979 models. This may be of great value to the OP and his 1974 182, but many of us are apparently experiencing at least similar problems in models of 1979 and beyond. - Andrew They all do it. If your Cessna is draining equally from both tanks, something is wrong!! |
Starting new C172s | navghtivs | Piloting | 76 | September 10th 05 09:33 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Mandatory SB565 Lycoming fuel pump | Paul kgyy | Owning | 18 | March 22nd 05 03:22 PM |
Most experienced CFI runs out of gas | Robert M. Gary | Piloting | 54 | November 19th 04 01:24 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
