Thomas Borchert wrote:
It was my (mis?)understanding that a diesel is, HP/lb, heavier than a standard aircraft engine, especially when getting into the higher (over 250) HP models. Correct? Not necessarily, but the big Thielert at 350 HP is heavier than an IO-520/550. 60 pounds or so. On the other hand, the diesel airplane will typically require less fuel in order to complete the same mission as the avgas airplane. The saved fuel weight can offset some or all of the weight penalty of the heavier engine. Of course this does not apply when topping off the tanks - but in that case, the diesel airplane gains a lot in range. So it looks like there is a free lunch after all - at least when not counting the acquisition costs! :-) Greetings, Markus |
Markus,
On the other hand, the diesel airplane will typically require less fuel in order to complete the same mission as the avgas airplane. Yes, but fuel is not usually stored at the very front end of the plane (think CG). -- Thomas Borchert (EDDH) |
Cirrus demo | Dan Luke | Piloting | 12 | December 4th 05 05:26 AM |
New G-1000 182 & Cirrus SR-22 GTS | Dan Luke | Piloting | 24 | June 27th 05 07:18 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
