Welding question 2
Old June 9th 06, 07:06 PM posted to rec.aviation.homebuilt
Default Welding question 2
Morgans wrote:
"Bill Daniels" bildan@comcast-dot-net wrote
That 'pop/sizzle' wirefeed/power bit is good advice. I kinda figgered
that out on my own and the results improved. The welder does have the
option of gas but I didn't borrow the regulator since the owner didn't
have a gas bottle or any solid wire. Would I be better off to change to
gas/solid wire?
Yep, the bottle would get you better results, both pretty wise, and easy
wise. It depends how much more you have to do, on this job. Not much to
do, forget it. If you have a lot to do, it might be worth getting it.
But outdoors, the gas will blow away without shielding the weld.
Flux core wire for outside work...
Old June 9th 06, 11:25 PM posted to rec.aviation.homebuilt
I had not thought of that, but I have never welded outside of a shop,
either. It has to do with big power supplies, and the availability
outdoors, I suppose.
Jim in NC
Welding question - Michael Horowitz Restoration 11 September 7th 06 03:52 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 02:36 PM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
