Welding question 2
Old June 10th 06, 01:48 AM posted to rec.aviation.homebuilt
Default Welding question 2
"pbc76049" wrote in message
Hey Bill.
If this is one of the cobra trailers with the rubber suspended
axle coming up thru the floor...... I'd stop and have a fab shop
add some stiffeners to the structure and have somebody do it
with the right tools. I'd HATE to have the trailer fail and break an
expensive plastic toy inside. YMMV
It's a Komet trailer and yes, the axle was coming up through the floor. I
have a new axle on order. The old one had a hardened rubber torsion member
which is probably the cause of the frame cracking. BTW, nothing wrong with
rubber torsion axles except the finite life - they're cheap to replace but
you have to do it every ten years.
There remains one possible problem. The new axle SHOULD bolt right up to
the frame bolts but the best computer work by a knowledgeable tech at the
"Red Neck Trailer Shop" (Honest, that is the name) couldn't assure that the
new one will fit so I may have to weld up a new attach points anyway..
I doubt this trailer will ever break again. I added enough extra square
tubing and angle to insure that. All the extra metal is welded in place
with aircraft grade oxy-acetylene welds. All I am doing with the wire-feed
buzz box is closing up the bottom. It's real hard to weld UP with an
oxy-acetylene torch.
Interestingly, when I grind the oxy-acetylene welds, they work the same as
the substrate. The wire feed beads, on the other hand, are much harder
than the substrate. The arc beads are like stellite.
Bill Daniels
Welding question - Michael Horowitz Restoration 11 September 7th 06 03:52 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 02:36 PM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
