Why don't wings have dimples?
Old June 12th 06, 08:08 AM posted to rec.aviation.homebuilt
Default Why don't wings have dimples?
In article . com,
"Dancing Fingers" wrote:
Hi all,
I always wanted to build my own airplane but the time and money has
eluded me. So I've decided to design and build my own recumbent trike,
with farings. This brings me to my question, if golf balls have
dimples, to help them sail further, why don't wings -- especially for
STOL aircraft? Would putting dimples in my faring reduce my wind
resistance?
Just curious.
Chris
First of all, golf balls have dimples because in order to create lift
they need to influence the air passing by them with the golf ball's
spin. The dimples help to make the air slow down beneath the ball and
speed up above it; creating downward flow.
Wings produce that downward flow with their shape.
Old June 13th 06, 06:51 PM posted to rec.aviation.homebuilt
("Alan Baker" wrote)
First of all, golf balls have dimples because in order to create lift they
need to influence the air passing by them with the golf ball's spin. The
dimples help to make the air slow down beneath the ball and speed up above
How about a dimpled spinner?
Your choice - slice or draw.
Montblack
Old June 14th 06, 01:55 AM posted to rec.aviation.homebuilt
"Alan Baker" wrote in message
In article . com,
Hi all,
resistance?
Just curious.
Chris
I believe that you have the effect exactly backward. The spin, which should
only be significant using the more steeply pitched irons; slows the relative
speed over the "top" of the ball and causes it to remain attached longer,
while the air flowing under the bottom breaks away more quickly, which would
result in a slight net lift. It also explains why a "slice" curves as it
does--which is why a smooth ball would have improved my game. :-(
Exactly.
Peter
Old June 14th 06, 06:20 AM posted to rec.aviation.homebuilt
In article . com,
Hi all,
resistance?
Just curious.
Chris
No. It doesn't. Golf balls spin with a rotation such that the bottom is
moving forward and the top is moving rearward.
Exactly.
Peter
Old June 14th 06, 06:29 AM posted to rec.aviation.homebuilt
Not the way I play... :-)
Old June 14th 06, 01:34 PM posted to rec.aviation.homebuilt
should
relative
longer,
Wait. That was my line!
Peter
Old June 14th 06, 08:33 PM posted to rec.aviation.homebuilt
should
relative
longer,
Peter
Oh well. The net effect is the same...
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
Charging for Wings safety seminar? Marty Shapiro Piloting 19 June 23rd 04 05:28 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Stolen "Champ" wings located...from 23,000 feet!! Tom Pappano Piloting 17 December 15th 03 01:24 PM
Wings from "Champ" stolen in Oklahoma after emergency landing Tom Pappano Piloting 1 December 7th 03 05:02 AM
