O/A welding question: tip size
Old June 14th 06, 11:42 PM posted to rec.aviation.homebuilt
Default O/A welding question: tip size
"Ken Moffett" wrote
32psi? That sounds more like "cutting tip" O2 pressure, not welding.
Yeah, you're right, it is. My mistake.
Ever try to weld with a cutting tip? Not easy, but it can be done! g I
wouldn't try to weld an airplane with a cutting torch, though.
Quite frankly, I do so little gas welding, I just play with it, until I like
it. I don't remember what I use. Does around 12 pounds sound about right?
That's what seems to come to mind.
Still, 2 pounds is not very much. I tend to use the knobs on the torch to
control the flow, as the most important control. I would think that if you
were using two pounds, you would have to have the knobs all of the way open.
I would think it would be hard to keep a consistent flame, like that.
Jim in NC
Old July 5th 06, 07:16 PM posted to rec.aviation.homebuilt
Cy Galley
Many are balanced pressure so 5 psi and 5psi might do the job,
"Morgans" wrote in message
like it. I don't remember what I use. Does around 12 pounds sound about
right? That's what seems to come to mind.
you were using two pounds, you would have to have the knobs all of the way
open. I would think it would be hard to keep a consistent flame, like
that.
Jim in NC
Old July 11th 06, 03:22 AM posted to rec.aviation.homebuilt
Skrud
I always set up for 5.0 - 5.5 psi on both the acetylene and oxygen,
regardless of tip size.
"Cy Galley" wrote in message
news:WlTqg.1060536$xm3.641273@attbi_s21...
I
about
to
way
that.
Jim in NC
Welding question - Michael Horowitz Restoration 11 September 7th 06 03:52 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 02:36 PM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Welding question Mike Restoration 4 February 20th 06 02:23 PM
Welding question Michael Horowitz Home Built 1 October 13th 05 09:53 PM
