Corrosion X
Old June 16th 06, 11:55 PM posted to rec.aviation.owning
Default Corrosion X
"Ronnie" wrote:
Just curious if anyone has ever suspected ACF-50 or
other corrosion treatment as being bad for some
plastic / bakelite type parts?
Nope.
My only gripe about Corrosion X is that it leaves oily streaks on the finish
(they wash off) for months after each application. Necessary evil, I
suppose.
Dan
C172RG at BFM
Old June 17th 06, 06:29 AM posted to rec.aviation.owning
Default Corrosion X
On Fri, 16 Jun 2006 17:55:06 -0500, "Dan Luke"
Nope.
suppose.
You "wash" your airplane? Next you'll be giving your cat a bath.
www.rogerhalstead.com
Old June 17th 06, 02:42 PM posted to rec.aviation.owning
Default Corrosion X
Heh.
My airplane is parked under cover but not in a hangar. At BFM, jet engines
and APUs are running almost constantly at Mobile Aerospace Engineering.
Jet-A soot, dust and salt spray stick to the plane overnight when it gets
wet from condensation. I can wash it on Sunday and it will be filthy again
by Friday, just by sitting there.
Usually, I just give it a quick squirt bath with the hose. About every
other month it gets a real wash.
Dan
C172RG at BFM
Pilatus B4 and corrosion Mika Koski Soaring 1 April 26th 06 09:50 PM
Corrosion Evaluation Help Dick Home Built 3 July 15th 05 02:51 AM
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Corrosion Proofing Clay Owning 7 April 22nd 05 12:03 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
