O/A welding question: tip size
Old June 20th 06, 07:10 PM posted to rec.aviation.homebuilt
Default O/A welding question: tip size
Mike,
Did the tip I let you borrow help?
I am building a mount for my HF Mobile antenna mount and may need your
help.
Hope to see you at the USO Swing Dance Saturday and the Poker Run
Sunday. If you can get in my 150, you can go with me on the Poker Run.
Fly Safe, Larry :-) O/O N22027, K4LLQ
mhorowit wrote:
Capt. Geoffrey Thorpe wrote:
But it sounds like, in spite of what your chart says,
you need to use a smaller tip. Just be sure you are getting enough of a
puddle on the sleeve as you turn down the heat.
Someone in the office suggests if I go to a much smaller tip, then the
area I'm heating will be smaller and therefore I may be introducing
stresses closer to the work.
Is that a consideration in the world of 4130? - Mike
Welding question - Michael Horowitz Restoration 11 September 7th 06 03:52 PM
Welding question: 43-13-1B, Fig.4-43 Mike Restoration 0 May 15th 06 02:36 PM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Welding question Mike Restoration 4 February 20th 06 02:23 PM
Welding question Michael Horowitz Home Built 1 October 13th 05 09:53 PM
