Jose wrote:
There is no regulation in the above proposal that requires multiple pilots (the requirement for the non-flying pilot to log PIC under 61.51(e). The FAR that requires multiple pilots says "simulated instrument conditions". As soon as you put the hood on, you are in simulated instrument conditions, whether in cloud or not, and whether IFR or not. You may =also= be in actual instrument conditions, but that is irrelevant. Are you sure about that part? I wouldn't have thought so. Brad |
Are you sure about that part? I wouldn't have thought so. I am not a lawyer and did not write the regs, so I am not "sure" what the end result of an actual case would be. However wearing a hood in IMC gives you all the disadvantages of simulated (vs actual) instrument flight. You are pretending to not be able to see outside. Look at it this way - if you are under the hood in VFR conditions (say under an overcast or in LA smog), you are in simulated conditions. If you enter cloud, you won't know it, because the simulation is so good. You can be VFR on a moonless night over water, and be in actual instrument conditions (perhaps we should use AIC instead of IMC), but put the hood on and you are in simulated instrument conditions. You won't know when you fly over a city. So it makes sense to me that you can simulate instrument conditions while you are actually in instrument conditions. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
I want to ask you the most important question of your life. | Douglas Olson | Owning | 1 | May 22nd 05 05:15 AM |
182RG question | Paul Anton | Owning | 11 | May 16th 05 09:45 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Could the Press Grow a Spine? | WalterM140 | Military Aviation | 259 | July 11th 04 08:35 PM |
