Back when I used to work on airplanes as an avionics tech, someone showed me
a neat trick for getting stuck screws loose. When you find a screw that doesn't want to come loose, or that the screwdriver tip cams out of, put a little valve grinding compound on the screwdriver tip. Valve grinding compound comes in a tube at auto parts stores, and has a fairly coarse grit in it. It gives your screwdriver tip much better traction in a screwhead that's already been a little damaged, and does a great job of preventing the screwdriver tip from camming out. There's also something similar available called "Screw Grab" that I found at a hardware store locally, that has the same grit in it but in a thinner solution. It works just as well. I rarely have to drill out screws since I started using those compounds. Scott Wilson |
wrote in message ...
[...] Valve grinding compound comes in a tube at auto parts stores, and has a fairly coarse grit in it. It gives your screwdriver tip much better traction in a screwhead I'm sure you'll get replies saying (in effect) "you didn't know that?" But thanks for posting the tip anyway. Lots of the rest of us didn't know it either. ![]() |
Peter Duniho wrote:
wrote in message ... [...] Valve grinding compound comes in a tube at auto parts stores, and has a fairly coarse grit in it. It gives your screwdriver tip much better traction in a screwhead I'm sure you'll get replies saying (in effect) "you didn't know that?" But thanks for posting the tip anyway. Lots of the rest of us didn't know it either. ![]() The Phillips ACR bit sold by Snap-On has serrations which reduce "cam-out". -- John Kimmel remove x "He's dead, Jim." |
Learning from an owner annual | Robert M. Gary | Piloting | 88 | July 5th 06 07:07 AM |
2006 Annual -- My 8th Owner Assisted -- Update | Jay Honeck | Owning | 14 | March 27th 06 07:11 PM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
