who here works for Garmin Inc?
Old July 6th 06, 05:52 AM posted to rec.aviation.owning
Dan[_1_]
Default who here works for Garmin Inc?
Which part on the power cable breaks specifically?
--Dan
Kobra wrote:
Better mount/cabling
engineering is needed, too.
Good point about the cabling! I forgot how horribily the power cable end is
engineered to fit into the back of the 396. That is a known weak point and
fails frequently. I am on my third power cable. Garmin asked no questions
and just sent me a new one.
I hope my postings are not an indication that I am dissatisfied with the
396. Quite the contrary...I love the unit and all the functionality that it
brings to the cockpit for the cost. I just hope there's room for the
improvements I mentioned without driving the cost up over 3,000.00. Other
than the touch screen, most of what I want should be able to be done with
new software, albeit it would also then need a faster processor and more
memory.
Kobra
Old July 6th 06, 12:29 PM posted to rec.aviation.owning
Dan Luke
The plug that goes into the GPS. It comes apart when you try to unplug it.
Old July 6th 06, 12:47 PM posted to rec.aviation.owning
Paul Tomblin
I recently bought a used 296. It came with a wall charger, a plane
charger and a car charger (the car charger differs from the plane charger
in that it has a speaker on it to give you directions when driving). The
car charger cord is broken in that the plastic shield has separated at the
strain relief, leaving just the internal wires to hold it together.
Paul Tomblin http://xcski.com/blogs/pt/
USER, n.:
The word computer professionals use when they mean "idiot".
Old July 6th 06, 03:45 PM posted to rec.aviation.owning
Kobra[_1_]
"The
Call Garmin...they will replace it free.
Kobra
Zero-Zero Landings In The Works (For Military Flyers) Otis Willie Naval Aviation 0 December 6th 05 02:01 AM
crazy but it works, espcially good if you need money happyone Piloting 0 July 24th 05 04:14 PM
New GPS from Honeywell/Bendix-King in the works Jim Burns Owning 8 June 21st 05 10:18 PM
Handheld GPS Works Fine, Except in One Particular Aircraft jls Home Built 3 July 5th 04 02:35 AM
