My name (mrsoaring) has been used re Microair boom mics I notice
I made about 1800 boom mics and about 1/2 of those were sold thru Microair but for the past 12 months they have made their own. The original mic (mine) was electret. Their new mics are amplified dynamic mics using aluminum fill. I once used aluminum fill - big mistake as it work hardens and springy. For the last 1000 or so mics they have been brass fill (11mm diameter) If you have one of those springy mics then best contact me direct and will do something for you (guess 3+ years old). I now make amplified dynamic which work with Microair, Xcom Icom Terra etc Genave Terra and a dynamic only for Becker Dittel etc Setting up in field I adj gain so it works well 1 or 2 cm from lips but does not work well when 10 to 15cm away. I listen on another radio 30m away. This is essential in open cockpit aircraft such as Tigermoth and open ultralights I am no longer listed as a Microair dealer on their web site but all I say is never take no from Microair till they get it right!! They do not like low voltage - I recommend use of 16g aircraft wire especially in big 2 seaters like ASH25. -18g is OK for single seaters - I recommend dual batteries and a good switch to use is C&K7211 with bat1 bat2 and OFF. Also be careful with voltage loss across those glass fuses -contacts can play up. Please fee free to contact me off line - go thru mrsoaring.com site Ian McPhee.(mrsoaring.com)... Byron Bay Australia "Bela Szalai" wrote in message ... Check the type of fuse(s) used between the battery terminals and the radio. On my first glider it took me months to realize that I had a slow blowing fuse that dropped the voltage about 0.5 volts and made transmission scratchy. - Béla ------Original Message----- -From: Glider Pilot Network ] -Sent: Tuesday, July 18, 2006 2:11 PM -To: Bela Szalai -Subject: [r.a.s] Microair Mic Problem - ------------------------------------------------------------- -Newsgroup: rec.aviation.soaring -Subject: Microair Mic Problem -Author: Henryk Birecki -Date/Time: 21:00 18 July 2006 ------------------------------------------------------------- -I keep hearing of problems with Microair radios, but mine -worked flawlessly for the past six years, or maybe rather 5 as -the first year I was fussing with home built mike system. No -problems since I got the Microair boom mike. - -The only "problem" I ever experienced is related to battery. -As the battery goes down you reach a point that you receive -just fine, but there is no transmission. I cannot compare -sensitivity to battery charge of Microair radio to others, but -I bet it is not significantly different. - -In case o significant problems, first thing I'd check is -antenna connection and antenna tuning. - -Henryk Birecki - -"palombian" wrote: - -I have a MicroAir 760 for 5 years in my glider and another -club member -before me Never problems - -JW - - wrote in message roups.com... - We have a Microair in our glider. It has never worked properly in - spite of a round-trip to Oz. We have given up on it, and now use - hand helds. - - Cheers anyway, Charles - - - - ------------------------------------------------------------- - |
Ongoing Arrow alternator/charging problem | Chuck | Owning | 6 | December 22nd 04 01:18 AM |
Mooney Engine Problem in Flight - Advise | Paul Smedshammer | Owning | 17 | December 21st 04 06:39 AM |
Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 10:38 PM |
Microair vs Becker | Ian McPhee | Soaring | 0 | August 30th 03 09:45 PM |
Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 03:06 PM |
