#11
![]() "Capt.Doug" wrote in message news:1UWvg.433226 You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. Somewhat correct Doug. At Fl 2, only slats 2,3,6,7 extend. At Fl 5, remaining slats (1,4,5,8) and all LE flaps (1-6) extend. Retract sequence is reverse. |
Doug, I had edited my original post, and should have mentioned that the
kruegers get retracted when changing from flaps 5 to flaps 2. At flaps 2, L.E. Flaps 2,3,6 and 7 are extended, and at 0 flaps, these get retracted also. "Capt.Doug" wrote in message ... "tom418" wrote in message Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. D. |
Correction: At flaps 2, SLATS 2,3,6,7 get retracted.
"tom418" wrote in message news:Rq2wg.163322$k%3.21020@dukeread12... Doug, I had edited my original post, and should have mentioned that the kruegers get retracted when changing from flaps 5 to flaps 2. At flaps 2, L.E. Flaps 2,3,6 and 7 are extended, and at 0 flaps, these get retracted also. "Capt.Doug" wrote in message ... "tom418" wrote in message Note: When 2 degrees of flaps are used, half of the slats get retracted , with the remaining slats (and the Krueger flaps) retracted with a 0 Flap setting You sure about the Krueger flaps? My library is packed away for remodeling preventing me from looking it up, but I'm sure only slats 3 &4 are extended at flaps2, not the Kruegers. D. |
![]() "Jim Macklin" wrote in message news:LbZvg.79434$ZW3.72823@dukeread04... Flaps the hinge at the bottom from of the leading edge and swing down to make a more curved section. Slats are sections of the leading edge that move forward making a slot. Ahaa! I thought they were all slats. -- Jim in NC |
"Morgans" wrote in message Ahaa! I thought they were all slats.
Additionally, on B-727 and B-732, the Krueger flaps will droop down after the hydraulic pressure is shut off. Turn the hydraulic pumps back on and they retract quickly. More than one mechanic has been hurt this way. D. |
C172N Flap indicator problem | onesto | Owning | 0 | July 2nd 06 10:47 AM |
Cirrus chute deployment -- an incredible story | Michael182/G | Instrument Flight Rules | 48 | July 14th 05 03:52 PM |
Stuck cowl flap cable | Jim Burns | Owning | 7 | March 24th 05 02:07 PM |
Flap angles | DeltaDeltaDelta | Piloting | 34 | May 18th 04 12:09 AM |
C-130 Unit Completes Two Year Deployment | Otis Willie | Military Aviation | 0 | September 30th 03 10:04 PM |
