![]() Peter R. wrote: Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to pick up my stranded Bonanza. The airport is only served by one instrument approach, a VOR/GPS approach, linked he http://www.myairplane.com/databases/.../06847VG18.PDF Until this approach, I had not encountered a non-precision approach without a published missed approach point. Is this more common than my experience has provided to date? Unless I am missing something obvious, the VOR is the missed approach point. There are hundreds (thousands?) of approaches like this where the missed begins at the navaid. |
Andrew Sarangan wrote:
Peter R. wrote: Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to pick up my stranded Bonanza. The airport is only served by one instrument approach, a VOR/GPS approach, linked he http://www.myairplane.com/databases/.../06847VG18.PDF Until this approach, I had not encountered a non-precision approach without a published missed approach point. Is this more common than my experience has provided to date? Unless I am missing something obvious, the VOR is the missed approach point. There are hundreds (thousands?) of approaches like this where the missed begins at the navaid. It also occurs BEYOND the departure end of the runway... |
![]() Dave S wrote: Andrew Sarangan wrote: Peter R. wrote: Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to pick up my stranded Bonanza. The airport is only served by one instrument approach, a VOR/GPS approach, linked he http://www.myairplane.com/databases/.../06847VG18.PDF Until this approach, I had not encountered a non-precision approach without a published missed approach point. Is this more common than my experience has provided to date? Unless I am missing something obvious, the VOR is the missed approach point. There are hundreds (thousands?) of approaches like this where the missed begins at the navaid. It also occurs BEYOND the departure end of the runway... So what? I would consider a MAP that begins before the runway to be an exception rather than the rule. That's what VDP's are for. Here are a few VOR approaches that begin beyond the departure end of the runway. http://www.myairplane.com/databases/...s/00958V24.PDF http://www.myairplane.com/databases/.../00863VG33.PDF http://www.myairplane.com/databases/...s/00863VG6.PDF http://www.myairplane.com/databases/.../00583VG4L.PDF |
It also occurs BEYOND the departure end of the runway... So what? I would consider a MAP that begins before the runway to be an exception rather than the rule. I agree.. But what I am referring to were MAPs that are reached after you have already passed the runway completely (approach AND departure end), and are leaving the airport boundary, which is portrayed in the approach in question. I'm sure there are more than a few.. I just haven't seen many like that. Thanks, Dave |
Dave S wrote:
Andrew Sarangan wrote: It also occurs BEYOND the departure end of the runway... So what? I would consider a MAP that begins before the runway to be an exception rather than the rule. I agree.. But what I am referring to were MAPs that are reached after you have already passed the runway completely (approach AND departure end), and are leaving the airport boundary, which is portrayed in the approach in question. I'm sure there are more than a few.. I just haven't seen many like that. Thanks, Dave That's why it's called a non-precision approach. You are suppose to understand on on-airport-faciliy's IAP limitations and be guided accordingly. These are antiques now. |
![]() That's why it's called a non-precision approach. You are suppose to understand on on-airport-faciliy's IAP limitations and be guided accordingly. These are antiques now. No... it's called a non precision approach if it lacks vertical guidance component in the form of a glideslope. And of course if it has a glideslope, its going to have a localizer or localizer type lateral guidance to the runway end.. what I thought was unique and remarkable about this approach, which nobody seems to notice what I was actually referring to.. was that the MAP wasnt before the runway, or over the threshhold, or over midfield.... but clean past the whole stinkin airport. Hadn't seen that before.. til now. Call me green.. I dont care.. I guess that isn't that remarkable of a thing to all the wise old men out there.. |
Dave S wrote:
what I thought was unique and remarkable about this approach, which nobody seems to notice what I was actually referring to.. was that the MAP wasnt before the runway, or over the threshhold, or over midfield.... but clean past the whole stinkin airport. The primary thing an approach does is make sure you don't hit anything. After that, it's good if it also gets you to a runway. |
Dave S wrote:
what I thought was unique and remarkable about this approach, which nobody seems to notice what I was actually referring to.. was that the MAP wasnt before the runway, or over the threshhold, or over midfield.... but clean past the whole stinkin airport. Hadn't seen that before.. til now. Keep in mind that what is important about the MAP is that it is not necessarily the point at which a safe descent to the runway will occur, or even the point at which the airport will be spotted, but rather that it is the point at which the pilot *begins* flying the missed approach. This is especially important on approaches such as Starke County (the approach linked and discussed in this thread) where it is imperative that the pilot continue along the final approach to the MAP before beginning the missed instructions. Terrain or man-made obstacles might dictate flying the final approach course past the airport before the missed can begin, or perhaps in this approach's case it was simply that the VOR was close enough to the airport to conveniently designate the missed approach point (although given that this VOR is co-located with a DME that could have been used to designate a closer MAP, maybe not)? Call me green.. I dont care.. I just rolled 1,000 hours with plenty of actual IMC and I still consider myself green. ![]() -- Peter |
Dave S wrote:
That's why it's called a non-precision approach. You are suppose to understand on on-airport-faciliy's IAP limitations and be guided accordingly. These are antiques now. No... it's called a non precision approach if it lacks vertical guidance component in the form of a glideslope. And of course if it has a glideslope, its going to have a localizer or localizer type lateral guidance to the runway end.. Some non-precision IAPs have more non-precision than others. what I thought was unique and remarkable about this approach, which nobody seems to notice what I was actually referring to.. was that the MAP wasnt before the runway, or over the threshhold, or over midfield.... but clean past the whole stinkin airport. Hadn't seen that before.. til now. Call me green.. I dont care.. I guess that isn't that remarkable of a thing to all the wise old men out there.. It is a matter of training, not experience. |
Dave S wrote:
Andrew Sarangan wrote: Peter R. wrote: Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to pick up my stranded Bonanza. The airport is only served by one instrument approach, a VOR/GPS approach, linked he http://www.myairplane.com/databases/.../06847VG18.PDF Until this approach, I had not encountered a non-precision approach without a published missed approach point. Is this more common than my experience has provided to date? Unless I am missing something obvious, the VOR is the missed approach point. There are hundreds (thousands?) of approaches like this where the missed begins at the navaid. It also occurs BEYOND the departure end of the runway... I think you meant to say the MAP occurs beyong the approach end of the runway. VOR and NDBs that are located on the airport are "on airport" approach facilities. The missed approach point is the facility even though it is beyond the landing threshold. The only exception is where it is a VOR/DME IAP, then a DME fix at the threshold will mark the MAP. |
Our first IFR cross-country trip: NY-MI-IL-MI-NY | Longworth | Piloting | 16 | July 15th 05 08:12 PM |
Video of VOR A approach into MBO in actual | A Lieberman | Instrument Flight Rules | 1 | May 2nd 05 03:35 PM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
Backup gyros - which do you trust? | Dan Luke | Piloting | 23 | July 17th 03 08:06 PM |
