![]() Part of the joy of homebuilding is the learning of new skills. Pick a proven design and go for it. To try to mix media in order to use what limited skills one already has just ends up in frustration, money spent and no flyable airplane in most cases. It helps to choose a design that's being built in your area by a friendly homebuilder who can show you how to do some of it. It also helps to be building an airplane for which materials are readily available. Be aware that suitable wood is increasingly rare and expensive and needs hangaring if it's to last any time at all. I own a wooden airplane, and the next will be aluminum. Dan |
Question about Alodine 1201 | Andrew Sarangan | Home Built | 20 | April 11th 06 01:31 PM |
Texas Parasol Plans... | Richard Lamb | Home Built | 82 | March 12th 06 07:19 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
