396 Magnet No More
Old August 19th 06, 05:33 AM posted to rec.aviation.owning,rec.aviation.piloting
Jon Kraus
Default 396 Magnet No More
I guess Garmin really does listen to us.... Got our 396 yesterday...
What a sweet piece of equipment by the way... I thought I would remove
the magnets in the GX30 antenna so I wouldn't have to mess with the
Whiskey compass getting spatially disoriented... I found the
instructions for removing the magnets (excellent detailed instructions
by the way) and sat down to perform the surgery. Imaging my suprise (and
delight) when there were no magnets to remove!!
I knew that the 496 didn't contain the dreaded magnets but I thought all
the 396's did. Guess Garmin really did "feel our pain".
Jon Kraus
'79 Mooney 201
4443H @ UMP
Old August 19th 06, 01:54 PM posted to rec.aviation.owning,rec.aviation.piloting
Doug Vetter
Jon Kraus
'79 Mooney 201
4443H @ UMP
How about scanning those instructions and posting them somewhere? My
396's antenna needs to be admitted for surgery as well...
-Doug
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old August 19th 06, 02:03 PM posted to rec.aviation.owning,rec.aviation.piloting
Jon Kraus
http://www.numa.aero/GXM30.html
That should be all you need. It will take you 10 minutes max to
accomplish... Good luck!!
Jon Kraus
(and delight) when there were no magnets to remove!!
all the 396's did. Guess Garmin really did "feel our pain".
Jon Kraus
'79 Mooney 201
4443H @ UMP
-Doug
Old August 19th 06, 10:45 PM posted to rec.aviation.owning,rec.aviation.piloting
Doug Vetter
Awesome Jon...thanks for that.
-Doug
Old August 21st 06, 02:21 AM posted to rec.aviation.owning
On 18-Aug-2006, Jon Kraus wrote:
Imaging my suprise (and delight) when there were no magnets to remove!!
Jon, were you able to determine that there were no magnets BEFORE you
performed the surgery? Is it your understanding that the magnetless
configuration is now standard on GX30 antennas?
The idea of putting magnets in a device intended (or at least likely) to be
placed atop an aircraft glareshield (and invariably in close proximity to
the wet compass) has to be put in the category of "what were they thinking?"
-Elliott Drucker
Old August 21st 06, 03:18 AM posted to rec.aviation.owning
Jon Kraus
Elliott,
I did not know that the GX30 was missing the magnets until I took it
apart. The GX30 antenna is quite heavy (compared to the GPS antenna) os
I thought or sure that the magnets were in there. I was quite suprised
that they were gone.
In hindsight I should have put a piece of steel by the antenna to see if
it was magnetized. Live and learn I guess. No harm no foul... I was able
to put the thing back together where no one could tell I had been in
there.
JK
-Elliott Drucker
Old August 21st 06, 05:05 PM posted to rec.aviation.owning,rec.aviation.piloting
Dave Butler[_1_]
Thanks for the link, Jon. Mine will be going under the knife as soon as I get
home from work.
DGB
Old August 22nd 06, 02:07 AM posted to rec.aviation.owning,rec.aviation.piloting
Jon Kraus
No problem Dave.... Make sure the "patient" is completely under before
plunging the knife in... ;-)
I get home from work.
DGB
Old August 22nd 06, 02:24 AM posted to rec.aviation.owning
Mike Spera
I am REALLY tempted to remove the critters, especially since you
provided the "heavy lifting" by trying it first.
After surgery, would anyone be able to tell the magnets were removed? I
am thinking of the fist fight I would have if that thing ever went in
for a warranty repair and was refused because the magnets were removed.
Also, does it help to heat the mags a bit to soften the glue?
Thanks,
Mike
Old August 22nd 06, 02:33 AM posted to rec.aviation.owning,rec.aviation.piloting
vincent p. norris
A member of our flying club sent this to me:
I looked into this when we bought the new GPS 396. While we can
remove the magnet from the base of the XM weather antenna, it will
void the warranty, which didn't seem like a good idea at the time.
Instead I made a steel plate that attaches to the dash by Velcro on
which to put the antenna. The steel works as a flux keeper and
contains the magnetic field enough that it has virtually no effect on
the compass. If you move the XM antenna and the steel plate together
from their current location to farther away from the compass you'll
see that the effect is almost, if not completely, imperceptible.
vince norris
396 Magnet No More Jon Kraus Piloting 6 August 22nd 06 02:33 AM
monitoring pusher props Ernest Christley Home Built 11 May 17th 06 12:53 AM
Mechanical tach failure? Rich S. Home Built 25 November 6th 04 04:30 PM
Afterburners in your pocket (the winged PDA is over the corner) Tamas Feher General Aviation 5 October 29th 04 07:18 PM
C177RG (1971) Hilton Piloting 9 August 17th 03 04:38 AM
