http://www.numa.aero/GXM30.html
That should be all you need. It will take you 10 minutes max to accomplish... Good luck!! Jon Kraus Doug Vetter wrote: Jon Kraus wrote: I guess Garmin really does listen to us.... Got our 396 yesterday... What a sweet piece of equipment by the way... I thought I would remove the magnets in the GX30 antenna so I wouldn't have to mess with the Whiskey compass getting spatially disoriented... I found the instructions for removing the magnets (excellent detailed instructions by the way) and sat down to perform the surgery. Imaging my suprise (and delight) when there were no magnets to remove!! I knew that the 496 didn't contain the dreaded magnets but I thought all the 396's did. Guess Garmin really did "feel our pain". Jon Kraus '79 Mooney 201 4443H @ UMP How about scanning those instructions and posting them somewhere? My 396's antenna needs to be admitted for surgery as well... -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
Jon Kraus wrote:
http://www.numa.aero/GXM30.html That should be all you need. It will take you 10 minutes max to accomplish... Good luck!! Awesome Jon...thanks for that. -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
I am REALLY tempted to remove the critters, especially since you
provided the "heavy lifting" by trying it first. After surgery, would anyone be able to tell the magnets were removed? I am thinking of the fist fight I would have if that thing ever went in for a warranty repair and was refused because the magnets were removed. Also, does it help to heat the mags a bit to soften the glue? Thanks, Mike |
In article k.net,
Mike Spera wrote: After surgery, would anyone be able to tell the magnets were removed? I am thinking of the fist fight I would have if that thing ever went in for a warranty repair and was refused because the magnets were removed. Removal of the magnets is obviously at your own risk, but a couple guys on the Piper Owner Society message boards removed the magnets and then sent the units it for (unrelated) warranty repairs. Garmin didn't flinch. Obviously, if you trashed your GXM30 removing the magnets, it would probably be noticed. JKG |
Jon Kraus wrote:
http://www.numa.aero/GXM30.html That should be all you need. It will take you 10 minutes max to accomplish... Good luck!! Thanks for the link, Jon. Mine will be going under the knife as soon as I get home from work. DGB |
No problem Dave.... Make sure the "patient" is completely under before
plunging the knife in... ;-) Dave Butler wrote: Jon Kraus wrote: http://www.numa.aero/GXM30.html That should be all you need. It will take you 10 minutes max to accomplish... Good luck!! Thanks for the link, Jon. Mine will be going under the knife as soon as I get home from work. DGB |
396 Magnet No More | Jon Kraus | Piloting | 6 | August 22nd 06 01:33 AM |
monitoring pusher props | Ernest Christley | Home Built | 11 | May 16th 06 11:53 PM |
Mechanical tach failure? | Rich S. | Home Built | 25 | November 6th 04 03:30 PM |
Afterburners in your pocket (the winged PDA is over the corner) | Tamas Feher | General Aviation | 5 | October 29th 04 06:18 PM |
C177RG (1971) | Hilton | Piloting | 9 | August 17th 03 03:38 AM |
