![]() If you don't already have a brass tail wheel, this is another option to move the CG back, and it is not too hard to swap in and out if needed. On my DG-303 the DG factory brass tail wheel (probably for a DG-1000, required a little machining to narrow it to fit into the DG-303, I'm not sure if AMS-Flight could provide one that fitted exactly). The tailwheel weighs somewhere around 8 pounds, I can't remember exactly. I'm around 185lb with parachute and with all equipment on board and a brass tail wheel the CG was back around 85% which is great for acro (spins nicely), for cross country it is too twitchy and I ballance it more forward with two of the standard weights in the cockpit floor compartment. It is nice if you find somebody with scales so you can be really sure where the CG is if you play around with things. Darryl DG-303 Acro 6DX John Schaffer wrote: I have a DG300 that has two tubes fiberglassed into the tail along the verticle stabilizer hinge line. These tubes are roughly 1" in diameter. According to the book it is for tailweight. The manual does not seem to explain how to use this feature or how to secure the weights. First impression is a lead bar similar to the old window sash bars. But how do you secure them so they do not move around? Thanx for any light you can shed John DG300 "XLT" -- John Schaffer |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
