![]() "Bill Daniels" bildan@comcast-dot-net wrote in message . .. "RST Engineering" wrote in message ... Join-solder the wires to the main cable with shrink over them, then shrink over the both wires, then a large shrink over the whole mess. A large dab of RTV at the center of the junction before you shrink, then the shrink will force the RTV into any voids in the junction. Jim Damn, RTV inside the shrink! Why didn't I think of that. Jim, please explain that again step by step. Which layers of shrink does the RTV go between? I'm thinking of glider trailer wiring. You can also buy a special shrink tubing that has a temperature sensitive adhesive inside. As you shrink the tubing, the adhesive melts around the cable and all is stuck together. Not a flexible as regular shrink, but great for outside applications such as antenna connectors, or glider trailers. There is also another specialized (but not cheap) shrink tubing called cold shrink. Think of a very wide pre-stretched rubber band. This stuff comes stretched around a core of spiral plastic. You put the tubing over the connection you want to seal, and then pull out the spiral core and watch the tubing immediately shrink around your joint. Not for headsets! Vaughn Vaughn Bill Daniels |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Calibrate? Repair? Adjust? | RST Engineering | Owning | 3 | April 4th 05 01:41 PM |
Panther C.A.T. headset. | Ross Taylor | Products | 0 | October 22nd 04 11:59 PM |
Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 03:09 AM |
headset plug repair | Michael C Finke | Owning | 14 | February 22nd 04 11:43 PM |
