Turn dynamics
Old September 26th 06, 08:58 AM posted to rec.aviation.piloting
Default Turn dynamics
Hi there,
Whoa! It's been a couple of years since I've posted on here. In fact,
looking through some of my previous threads, I was quite the confused
boy back then....and, in a moment of reflection, I've managed to come
up with a topically-similar inquiry. I read through all my old posts
and I couldn't quite get my hands on a definitive answer. So here it
is...
Suppose you're flying trimmed at 100 knots in your Cessna 172, straight
and level, on the front side of the power curve. You enter a 60 deg.
bank that doubles your load factor. Your lift requirement doubles.
Further suppose your goal is to maintain altitude in this turn. To
meet achieve twice the lift, you pull back on the stick to augment the
angle of attack, maintaining airspeed. Everything's good so far? The
up/down forces are balanced. Let's look at drag now.
Banking at 60 deg. and thus pulling 2 g's has shifted every point on
the power required vs. airspeed to the right and up.
Recall that in this scenario, the airspeed has NOT changed. We've only
increased the angle of attack as required, to get twice the lift.
1st question: Is the problem setup flawed? If so, please tell me. I
haven't flown in years
2nd question: In the turn, my (L/D)max airspeed has increased by 41%
(sqrt 2) as the (L/D)max airspeed point for the 1g condition has
shifted to a higher airspeed for the 2g condition. Given this
scenario, the airplane in question, and the fact that my airspeed has
NOT changed, am I likely to find myself flying on the FRONT or BACK
side of the power curve in this constant-airspeed turn? What is your
rationale?
3rd question: Given this scenario and the airplane in question, is it
likely that at that same airspeed, the drag and power required at 2g
are HIGHER than at the 1g condition? Why?
4th question: If the answer to (3) is yes, is throttling up the only
way of maintaining altitude in this turn?
5th question: Further to question 4, suppose that I am already at full
throttle, unable to increase thrust, and wish to maintain altitude.
The only remaining variable that I can change is airspeed via yoke
position, by pulling or pushing. Would you agree that I would have to
push on the yoke to maintain altitude if I was on the backside of the
2g power curve and pull on the yoke to maintain altitude if I was on
the front side of 2g power curve? Does it seem counterintuitive to
push on the yoke to maintain altitude in a turn? Something sounds
fishy.
Thanks for any insight.
Alex
Old September 26th 06, 09:38 AM posted to rec.aviation.piloting
Peter Duniho
[...] Does it seem counterintuitive to
fishy.
Sure, of course something sounds fishy. That would be your clue that your
analysis is wrong.
I don't fully even understand what you're trying to propose. For one, you
can't increase your load factor (and thus lift) without either increasing
thrust or decreasing airspeed. The moment you increase the lift, drag
increases and the airplane will start to slow down until thrust equals drag
again.
As far as the parts of your question that I think I comprehend go...
From personal experience, at 100 knots in a C172, you will remain on the
"front side of the power curve" with the proposed maneuver. That is, a
reduction in airspeed will compensate for the increased drag. That said, of
course if you select a power setting that provides less thrust than the
minimum drag at the doubled lift, you cannot expect to enter a 60 degree
bank and remain in level flight. Even at L/Dmax, engine thrust will be less
than drag and the airplane will slow further into the "back side of the
power curve". Only by descending can you get enough thrust to balance drag.
Note that in this latter case, being on the "back side of the power curve"
won't help you. Yes, speeding up would reduce drag, but the reason you get
into that situation in the first place is that there's NO airspeed at which
you can reduce drag enough to be below or equal to the available thrust.
Even if you speed up to exactly L/Dmax airspeed, you still need to maintain
a descent, because there's just not enough engine thrust. All that speeding
up gets you is a shallower descent angle (just as would be the case in a
straight-ahead descent).
In other words, being in a 60 degree bank doesn't change the basic
concepts...only the specific airspeeds at which things happen. This all
assumes, of course, that you *start* on the "front side of the power curve".
If you are in level flight on the "back side", then yes...speeding up allows
you to fly with less thrust, the excess then which you can then use to
compensate for drag induced by a bank.
All of the above is posted in good faith. You are correct when you say you
were confused back when you posted previously, but I have to say that
today's post exhibits some of the same "overcomplicating" behavior we saw
back then. You don't get something for nothing, and no matter how you
manage to state the question, the airplane always flies the same. I hope
this question doesn't devolve into a similar quagmire as we saw "back then".
I know I don't have the patience for it.
Pete
Old September 26th 06, 04:43 PM posted to rec.aviation.piloting
Hey Pete,
I knew I could count on you to give me the first cuttingly informative
reply. I was going to post some follow-up questions but nah...it's not
worth the patronizing.
Thanks for your time, and the warm welcome.
fishy.
analysis is wrong.
again.
Pete
Old September 26th 06, 08:34 PM posted to rec.aviation.piloting
Dan Luke
Hey Pete,
If your feelings get hurt that easily, usenet is not the place for you to be
asking questions.
Dan
C-172RG at BFM
Old September 26th 06, 10:49 PM posted to rec.aviation.piloting
There's plenty of people on usenet who answer questions without being
condescending.
Dan Luke wrote:
Hey Pete,
asking questions.
Dan
C-172RG at BFM
Old September 26th 06, 07:23 PM posted to rec.aviation.piloting
Jose[_1_]
No, not really. When you pull back on the stick, you will lose
airspeed. In order to maintain airspeed, you will need power. If you
also apply power at the same time as you pull back on the stick (at the
same time you are in the 60 degree banked turn) then you can maintain
airspeed and altitude.
Once you get your head around the need for power at this point, the
answers to the rest of your questions should become clearer.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old September 26th 06, 11:35 PM posted to rec.aviation.piloting
Hi Jose,
When I formulated the scenario, I broke it down into two phases.
The first phase was related to the forces perpendicular to the relative
wind, or the action of pulling back on the stick and increasing your
angle of attack enough to meet the increased lift requirement, with no
change in airspeed. This essentially satisfied lift = 2*weight. I
then looked at the changing forces parallel to the relative wind
(thrust/drag) in the second phase.
The increase in drag due to the higher load factor would slow you, and
you'd soon find yourself pitched down and descending, followed by a
restauration of the initial airspeed flown before and during the turn
(with no change in power, that is). As I understand, one could apply
additional power to maintain altitude and airspeed in the turn though.
My questions pertained to the second phase, and regarded the increase
in drag/power required and their effect on the maintenance of altitude.
Perhaps we're saying the same thing? (and perhaps not...in which case
I'd appreciate another round of clarification)
Thanks for your input.
Alex
Jose
Old September 27th 06, 12:16 AM posted to rec.aviation.piloting
Jose[_1_]
If you mean "what happens first" and "what happens second" then I follow
you. Otherwise,
change in airspeed.
.... doesn't work.
That is, the airspeed won't change instantaneiously, but it will change,
because the steady state is unsustainable without more power. Maybe
that's what you mean by the second phase: (The increase in drag due to
the higher load factor would slow you...)
If that's what you meant, then you're ok.
and
What are you doing with the stick? (same position? same forces? same
airspeed?)
It's slightly different, but you might be able to get your head around
it better, if you think of Uncle Bob parachuting into your airplane.
There you are, fat, dumb, and happy, flying straight and level. (I'm
going to make all the numbers up here out of whole cloth). Uncle Bob
parachutes right into your airplane, and amazingly lets go of the canopy
and fixes the airframe faster than you can say "337". But he's now in
the plane.
IF YOU DO NOTHING, the plane will descend, because lift hasn't changed,
but weight has. To compensate, you pull back on the stick, increasing
lift (at the expense of drag). Now with the nose pointing in the air,
you maintain altitude, but you're going slower because the extra drag,
and also partly because the thurst vector is now pointing more up, and
less in the direction of flight.
To go faster without gaining altitude, you must lower the nose (again)
=and= add power. You will need a higher airspeed than originally to
provide sufficient lift (you need to hold Uncle Bob up too!) if you
attempt to hold the same angle of attack as you originally had, but
that's not what you want. You want your orignal airspeed, AOA be
damned. So, at that original airspeed (which of course requires more
power), you'll need a higher AOA.
You can generate the same lift at a range of AOA and power. Doing this
with more power requires you to go faster. Doing it with a higher AOA
requires you to go slower. You pick the one combination that gives you
the desired (original) airspeed. It will be a higher-than-original AOA,
with higher-than-original power.
Most of this thinking would apply to the turning flight too, but it
might be easier to think of it in this context first. (btw, this is the
context of airdrops in reverse - you drop your load, you need to reduce
power and pitch down if you want to maintain altitude and airspeed).
Jose
Old September 27th 06, 12:39 AM posted to rec.aviation.piloting
you.
yeah, that's what I meant. What I referred to as the first phase is
"what happens first" and the second phase is "what happens thereafter".
The second phase follows the first.
Are we in agreement?
Alex
Change in AIM wording concerning procedure turn Kris Kortokrax Instrument Flight Rules 208 October 14th 05 12:58 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Rate of turn indicator on commercial jets (Boeing / Airbus) Mark Simulators 1 November 1st 03 10:35 AM
