![]() Ernest Christley wrote: What is the best way to secure plastic tubing to aluminum pitot tubes. The plastic hose will slide over the aluminum tube, though it requires quite a bit of push to get more than 1/2". Would a couple of spring clamps work, or is something more significant called for? Hi, Use a hair drier to warm the plastic tube and it will slide more easily. While the tube is still warm use a small tie wrap. Voilą! Regards, S6 |
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup | Juan Jimenez | General Aviation | 7 | September 19th 06 10:20 PM |
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup | Juan Jimenez | Aviation Marketplace | 7 | September 19th 06 10:20 PM |
Proposed AD ECi connecting rods | Jim Burns | Owning | 8 | October 8th 05 04:27 PM |
Seeking US Source for Main Wheel Tubes | Chris OCallaghan | Soaring | 7 | August 28th 04 03:46 PM |
Rockets used in al-Rashid hotel match "aluminum tubes" rockets | Robb McLeod | Military Aviation | 7 | October 28th 03 07:49 AM |
