Connecting hoses to pitot/static tubes
Old October 22nd 06, 04:29 AM posted to rec.aviation.homebuilt
Default Connecting hoses to pitot/static tubes
On Sat, 21 Oct 2006 23:24:01 -0400, "Morgans" wrote:
What is the best way to secure plastic tubing to aluminum pitot tubes.
The plastic hose will slide over the aluminum tube, though it requires
quite a bit of push to get more than 1/2". Would a couple of spring
clamps work, or is something more significant called for?
I put a twist of safety wire around it....
Do you go around it twice before twisting, to avoid "bunching" ?
"You only go around once in life...."
....and so do my pitot/static safety wires. Maybe that explains my 150 knot
cruise. :-)
Old October 22nd 06, 05:00 AM posted to rec.aviation.homebuilt
Morgans[_2_]
cruise. :-)
Chuckle out loud
Perhaps you got one of those wires twisted tooo tightly in the wrong place.
Perhaps around your "truth tube", whatever that is!
(get your mind out of the gutter-it was not meant "that" way!)
Jim in NC
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez General Aviation 7 September 19th 06 10:20 PM
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez Aviation Marketplace 7 September 19th 06 10:20 PM
Proposed AD ECi connecting rods Jim Burns Owning 8 October 8th 05 04:27 PM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 03:46 PM
Rockets used in al-Rashid hotel match "aluminum tubes" rockets Robb McLeod Military Aviation 7 October 28th 03 07:49 AM
