Alan,
my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Alan, my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. |
I wouldn't go that far. We are also building good habits and attitudes for the future. One day we may be flying jet aircraft, who knows? The attitudes you start out with are likely to be the attitudes you end up with, and the skills you learn from day one are the ones that come back to you in an emergency. However, yes, there is plenty of room in the hold for a spam can. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote:
At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. One day we may be flying jet aircraft, who knows? The attitudes you start out with are likely to be the attitudes you end up with, and the skills you learn from day one are the ones that come back to you in an emergency. I have posted almost exactly the same comments here in the past. Of course, you are correct. The "recommended" entries are really mandatory for jet aircraft operating at the max permitted speeds. And, so forth. However, yes, there is plenty of room in the hold for a spam can. Exactly. |
Jose wrote:
At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. Right. And a good attitude is to not get bogged down in minutia like calculating outbound leg times for NDB holds when there's more important stuff to be thinking about. What's the weather doing? What's my fuel situation, i.e. how long can I let ATC park me here before I need to head to my alternate? What is my best alternate given the current situation? Can I review the approach plate one more time to make sure I really understand the procedure. |
Roy Smith wrote:
Jose wrote: At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. Right. And a good attitude is to not get bogged down in minutia like calculating outbound leg times for NDB holds when there's more important stuff to be thinking about. What's the weather doing? What's my fuel situation, i.e. how long can I let ATC park me here before I need to head to my alternate? What is my best alternate given the current situation? Can I review the approach plate one more time to make sure I really understand the procedure. And, what are the odds of having to hold at an NDB in the 21st Century? |
In article , Sam Spade
wrote: And, what are the odds of having to hold at an NDB in the 21st Century? Essentially zero. But, if your instructor (or flight school) is dumb enough to send you for an instrument checkride in an airplane equipped with an ADF, you may be called upon to demonstrate one. Which means they need to train you to be able to perform one. Which, of course, is a huge waste of your time and money, since it's a skill you will never use again after the checkride. Which is why, earlier in this thread, I said: But, the real way to do NBD holds is to tear that piece of crap ADF out of the panel and train in a GPS-equipped airplane. If your school doesn't have GPS in their trainers, find another school. |
Roy Smith wrote:
In article , Sam Spade wrote: And, what are the odds of having to hold at an NDB in the 21st Century? Essentially zero. But, if your instructor (or flight school) is dumb enough to send you for an instrument checkride in an airplane equipped with an ADF, you may be called upon to demonstrate one. Which means they need to train you to be able to perform one. Which, of course, is a huge waste of your time and money, since it's a skill you will never use again after the checkride. Although I have never been assigned an NDB hold in the U.S, I have been assigned NDB routes and holds in Canada. Just a couple of months ago, I was instructed to hold at the Muskoka NDB. A few months earlier, I was given "expect NDB approach... into Buttonville airport". This airport is one of the largest GA fields in Toronto and has a perfectly good LOC approach, but folks up there don't seem to shy away from NDBs. |
On Sat, 28 Oct 2006 12:12:01 -0700, Sam Spade wrote:
And, what are the odds of having to hold at an NDB in the 21st Centur On a few occasions, I've held at an NDB, but only one of those occasions was in the 21st century, and not in the past few years since I've had a GPS. I held at the EPM NDB for 1/2 hour or so waiting for weather to improve, before we had a GPS approach. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On 10/28/06 08:24, Sam Spade wrote:
Thomas Borchert wrote: Alan, my notes it says to work out the timings use 75% of the head / tail wind factor. Hmm. Why not 100 percent? The way I would do it is to figure out the percentage the head/tail wind is of my IAS (TAS, if you want to get precise). Then, I would correct 1 minute by that percentage. From your notes, your supposed to take 75 percent of that percentage. In reality, this takes way too much brain power away from controlling the aircraft. Make intelligent guesses. E.g. your holding speed is 90 knots, your wind component is an estimated 10 knots, so you try a 10 seconds correction. At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. Exactly. I think if you show the inspector that you: 1. consider the crosswind when taking a guess at your outbound and inbound headings; 2. consider the head/tail wind when taking a guess at your initial outbound timing; 3. make a reasonable adjustment to your second outbound timing after seeing what your first inbound leg time was. he will be impressed. Note that in all three cases, all that will matter is that you make the correction in the right direction; the *amount* of the correction won't matter to them. I know that during training, I would like to go around the holds over and over, making minor corrections to try to get the time and heading to work out perfectly - my instructor would just get bored and make us move on ;-) -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
Academy holds memorial dedication for Navy's Blue Angels | Otis Willie | Naval Aviation | 0 | May 27th 06 04:01 AM |
timing holds | [email protected] | Instrument Flight Rules | 16 | February 17th 05 12:18 AM |
Holds when PT NA | David Rind | Instrument Flight Rules | 19 | April 9th 04 08:28 PM |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
Yokota holds memorial service for NCO | Otis Willie | Military Aviation | 0 | August 15th 03 09:22 PM |
