At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft.
I wouldn't go that far. We are also building good habits and attitudes for the future. One day we may be flying jet aircraft, who knows? The attitudes you start out with are likely to be the attitudes you end up with, and the skills you learn from day one are the ones that come back to you in an emergency. However, yes, there is plenty of room in the hold for a spam can. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote:
At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. One day we may be flying jet aircraft, who knows? The attitudes you start out with are likely to be the attitudes you end up with, and the skills you learn from day one are the ones that come back to you in an emergency. I have posted almost exactly the same comments here in the past. Of course, you are correct. The "recommended" entries are really mandatory for jet aircraft operating at the max permitted speeds. And, so forth. However, yes, there is plenty of room in the hold for a spam can. Exactly. |
Jose wrote:
At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. Right. And a good attitude is to not get bogged down in minutia like calculating outbound leg times for NDB holds when there's more important stuff to be thinking about. What's the weather doing? What's my fuel situation, i.e. how long can I let ATC park me here before I need to head to my alternate? What is my best alternate given the current situation? Can I review the approach plate one more time to make sure I really understand the procedure. |
Roy Smith wrote:
Jose wrote: At 90 knots it all is just b.s. to try to placate some anal instructor or check airperson. The holding pattern protected airspace is designed for a jet aircraft. I wouldn't go that far. We are also building good habits and attitudes for the future. Right. And a good attitude is to not get bogged down in minutia like calculating outbound leg times for NDB holds when there's more important stuff to be thinking about. What's the weather doing? What's my fuel situation, i.e. how long can I let ATC park me here before I need to head to my alternate? What is my best alternate given the current situation? Can I review the approach plate one more time to make sure I really understand the procedure. And, what are the odds of having to hold at an NDB in the 21st Century? |
In article , Sam Spade
wrote: And, what are the odds of having to hold at an NDB in the 21st Century? Essentially zero. But, if your instructor (or flight school) is dumb enough to send you for an instrument checkride in an airplane equipped with an ADF, you may be called upon to demonstrate one. Which means they need to train you to be able to perform one. Which, of course, is a huge waste of your time and money, since it's a skill you will never use again after the checkride. Which is why, earlier in this thread, I said: But, the real way to do NBD holds is to tear that piece of crap ADF out of the panel and train in a GPS-equipped airplane. If your school doesn't have GPS in their trainers, find another school. |
Roy Smith wrote:
In article , Sam Spade wrote: And, what are the odds of having to hold at an NDB in the 21st Century? Essentially zero. But, if your instructor (or flight school) is dumb enough to send you for an instrument checkride in an airplane equipped with an ADF, you may be called upon to demonstrate one. Which means they need to train you to be able to perform one. Which, of course, is a huge waste of your time and money, since it's a skill you will never use again after the checkride. Although I have never been assigned an NDB hold in the U.S, I have been assigned NDB routes and holds in Canada. Just a couple of months ago, I was instructed to hold at the Muskoka NDB. A few months earlier, I was given "expect NDB approach... into Buttonville airport". This airport is one of the largest GA fields in Toronto and has a perfectly good LOC approach, but folks up there don't seem to shy away from NDBs. |
"Andrew Sarangan" wrote:
Although I have never been assigned an NDB hold in the U.S, I have been assigned NDB routes and holds in Canada. Just a couple of months ago, I was instructed to hold at the Muskoka NDB. A few months earlier, I was given "expect NDB approach... into Buttonville airport". This airport is one of the largest GA fields in Toronto and has a perfectly good LOC approach, but folks up there don't seem to shy away from NDBs. Well, then I would fall back (yet again) to what I said earlier in this thread: But, the real way to do NBD holds is to tear that piece of crap ADF out of the panel and train in a GPS-equipped airplane. If your school doesn't have GPS in their trainers, find another school. Any flight school (at least in the US) which is not doing instrument training in GPS equipped airplanes today is just ripping off their students. GPS is no longer the way of the future, it's the way of today. I don't think you can buy a new IFR airplane today which doesn't come with GPS as standard factory equipment. This is everyday, routine gear for the majority of the GA fleet. Not training new instrument pilots to use GPS is like not training new primary students to use a nosewheel. The way to do an NDB hold today is to punch the NDB name into your GPS and hold at it just like you would at any other fix. If I was going into Buttonville, and there wasn't a GPS overlay for the NDB, I would tell the controller, "unable NDB approach, request LOC". |
Roy:
Expecting (assuming) all IFR training in the US to be in aircraft that have IFR-certified GPS is a bit unrealistic. Would you like to pay for an IFR-certified GPS to be installed in my cherokee? I'd be delighted, and would even buy you dinner. |
On Sat, 28 Oct 2006 12:12:01 -0700, Sam Spade wrote:
And, what are the odds of having to hold at an NDB in the 21st Centur On a few occasions, I've held at an NDB, but only one of those occasions was in the 21st century, and not in the past few years since I've had a GPS. I held at the EPM NDB for 1/2 hour or so waiting for weather to improve, before we had a GPS approach. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Academy holds memorial dedication for Navy's Blue Angels | Otis Willie | Naval Aviation | 0 | May 27th 06 04:01 AM |
timing holds | [email protected] | Instrument Flight Rules | 16 | February 17th 05 12:18 AM |
Holds when PT NA | David Rind | Instrument Flight Rules | 19 | April 9th 04 08:28 PM |
Holds for currency requirements | Paul Tomblin | Instrument Flight Rules | 8 | March 12th 04 06:49 PM |
Yokota holds memorial service for NCO | Otis Willie | Military Aviation | 0 | August 15th 03 09:22 PM |
