NDB Holds
Old October 30th 06, 03:38 AM posted to rec.aviation.ifr
Blanche
Default NDB Holds
Roy Smith wrote:
Blanche wrote:
Expecting (assuming) all IFR training in the US to be in aircraft
that have IFR-certified GPS is a bit unrealistic.
I guess that depends on your definition of "realistic".
I certainly think it is inappropriate, in the year 2006, to be giving
instrument training in an airplane that is not IFR GPS equipped. You
should be training people to operate in the kind of environment they are
going to be flying in after they pass their checkride. For the most part,
that means GPS. And that's going to be even more true every year that goes
by.
Would you like to pay for an IFR-certified GPS to be installed in
my cherokee? I'd be delighted, and would even buy you dinner.
I take it that you use your cherokee for instrument instruction? If that's
the case, then you should invest the capital to equip it with gear which
allows you to teach your students what they need to know. I'm afraid I
have no particular desire to fund the upgrade to your plane, however.
I'm not the teacher, I'm the student. My cherokee. And I don't have
an extra $4-8K to install an IFR-certified GPS. And the cherokee *IS*
the environment I expect to be flying after my checkride. Flying is
not my profession, nor will it be a career change.
Please, lay off the assumptions. Feel free to qualify your opinions
(and yes, they are valid but not in all situations) but make sure you
define your criteria.
Old October 30th 06, 02:17 PM posted to rec.aviation.ifr
Roy Smith
Default NDB Holds
OK, so my comment didn't apply to you. I was complaining about flight
schools who teach in non-GPS equipped airplanes. If you own your own
airplane, you can obviously equip it any way you like, and you're the only
one you have to answer to about your decisions.
Well, I started out by saying:
Any flight school (at least in the US) which is not doing instrument
training in GPS equipped airplanes today is just ripping off their students.
Clearly, that doesn't apply to you. Thus, I don't understand why you took
exception to it.
Old October 30th 06, 02:40 PM posted to rec.aviation.ifr
Sam Spade
Default NDB Holds
Blanche wrote:
Roy:
That comparison is irrelvant.
Roy is speaking of trainers at a school that holds itself out to the
public to provide IFR flight training.
You are talking about your own personal airborne "rattletrap."
Old October 30th 06, 04:19 PM posted to rec.aviation.ifr
Sam Spade
Default NDB Holds
I'll give you something more concrete than an assumption: 10 years from
now, you might as well forget about conducting IFR operations in a light
aircraft if you don't have a TSO-C146 box.
So, it is really a limited form of training *today* to do all that work
for an instrument rating without becoming proficient in GPS operations
in the process.
Old October 30th 06, 05:33 PM posted to rec.aviation.ifr
Newps
Default NDB Holds
Baloney. Operations won't be any different in ten years than they are now.
Old October 30th 06, 07:03 PM posted to rec.aviation.ifr
Sam Spade
Default NDB Holds
Newps wrote:
from now, you might as well forget about conducting IFR operations in
a light aircraft if you don't have a TSO-C146 box.
Might be balony to you but it isn't to the folks that run the FAA.
Old October 30th 06, 10:56 PM posted to rec.aviation.ifr
Roger (K8RI)
Default NDB Holds
Most trainers don't have instrumentation that old.
That means they have to put the ADF back in for my training.
by.
I fly IFR in the system using VORs, RNAV, and NDBs. The only GPS I
have/own is a hand held.
www.rogerhalstead.com
  #28
Old October 31st 06, 07:10 PM posted to rec.aviation.ifr
Kusi (us-ppl, sep, d.-ir)
Default NDB Holds
Alan Burke wrote:
Hi,
I'm studying for my IR and having some trouble in calculating the outbound
times. Has anyone got any easy way of calculating the times.
Just finished mine over here in Germany. We were supposed to learn it,
however our flying clubs' Pipers have 2 GNS 430, with the excellent
"pictures"...
Anyway: Here is an easy method, if you have lets say 3+ miles to go in
a 100kts airplane:
Time: Subtract/Add the Wind-speed in seconds from/to your 1 min as
follows:
Wind angle 30° full speed. Wind angle 30..60° half speed. Wind angle
60° no correction.
Example: Wind 300/20, Course 290°. Wind angle=10°, that is "full
speed" so ADD 20seconds (20kts) to your 1 min.
By the way, that works with VORs as well.
Of course, in the real world, in a small plane...who gives a f* ?
You'll stay almost always in the protected area, no matter what heading
you fly.... ;-)
Cheers,
Kusi
Academy holds memorial dedication for Navy's Blue Angels Otis Willie Naval Aviation 0 May 27th 06 04:01 AM
timing holds [email protected] Instrument Flight Rules 16 February 17th 05 12:18 AM
Holds when PT NA David Rind Instrument Flight Rules 19 April 9th 04 08:28 PM
Holds for currency requirements Paul Tomblin Instrument Flight Rules 8 March 12th 04 06:49 PM
Yokota holds memorial service for NCO Otis Willie Military Aviation 0 August 15th 03 09:22 PM
