I never knew you were supposed to replace tubes. I went 30 years
on a set in my Bonanza. Now that they are replaced, I can say the new ones leak about as much as the 30 year old ones. Bill Hale Ben Jackson wrote: On 2006-10-26, RK Henry wrote: On Thu, 26 Oct 2006 14:30:56 -0500, Ben Jackson wrote: How "decidedly not" new are the existing tires? If they're going to be replaced soon, you could store the tubes until you need them. Of course you run the risk that you might sell the airplane before that. Ben Jackson AD7GD http://www.ben.com/ |
![]() "Ben Jackson" wrote in message ... On 2006-11-01, wrote: Now that they are replaced, I can say the new ones leak about as much as the 30 year old ones. My new ones are butyl based (not "airstop", but another brand). They should hold their air much longer. -- Ben Jackson AD7GD http://www.ben.com/ Fill them with Nitrogen they won't leak as much. Not that I've tried it. |
On 2006-11-01, Gig 601XL Builder wrote:
Fill them with Nitrogen they won't leak as much. Not that I've tried it. The way my A&P drives a nitrogen cylinder they wouldn't leak because the wheel halves would be in different counties... -- Ben Jackson AD7GD http://www.ben.com/ |
Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. |
"Ray Andraka" wrote in message
... Gig 601XL Builder wrote: Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. And, that few percent difference makes a small fraction of a percent difference in how fast they leak. Not enough to notice, but enough that tire stores around here (Detroit) make all kinds of wild claims about the advantages of buying tires from them and having them filled with N2... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Because back in the good old daze when inner tubes weren't quite as well
done from a chemistry point of view the oxygen in the air WOULD attack the rubber and cause it to deteriorate quicker than with pure nitrogen. Back when I wuz wit da airlines, we used nitrogen exclusively to fill tires on the torches. Jim "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:hdSdnbmXe9pLpNTYnZ2dnUVZ_sidnZ2d@wideopenwest .com... "Ray Andraka" wrote in message ... Gig 601XL Builder wrote: Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. And, that few percent difference makes a small fraction of a percent difference in how fast they leak. Not enough to notice, but enough that tire stores around here (Detroit) make all kinds of wild claims about the advantages of buying tires from them and having them filled with N2... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Ray Andraka" wrote in message ... Gig 601XL Builder wrote: Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. As I said I haven't tried it but there are 398,000 hits when you Google Nitrogen filled tires. I saw and ad for it in one of the aircraft mags the other day and hadn't really looked into it that much. But glancing at the Google results the opinions are mixed between works well and snake oil. |
"Ray Andraka" wrote in message ... Gig 601XL Builder wrote: Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. As I said I haven't tried it but there are 398,000 hits when you Google Nitrogen filled tires. I saw and ad for it in one of the aircraft mags the other day and hadn't really looked into it that much. But glancing at the Google results the opinions are mixed between works well and snake oil. There are reasons for using nitrogen in tires, but leakage isn't one of them. From what I understand, high pressure tires often need nitrogen because if regular air was used the high pressure of the oxygen mix becomes combustible and can lead to tire fires. In our spam cans though, the pressures aren't high enough to cause problems. There's also the convenience thing if you happen to have bottled nitrogen in the hangar, and finally some have said that it keeps the rubber from oxidizing, but I doubt that is a real issue since the outsides will deteriorate long before the inside oxidizes enough to be a problem. |
I don't know the practical aspects of N2 v O2 in modern tubes, but the
partial pressure of O2 in a tire inflated to 30 psi is 3x that on the outside of the tube. If anything in the rubber tended to oxidize, it would oxidize significantly faster at the higher O2 partial pressure. It may not be a practical problem in tubes, but I'll bet it makes a difference in a strut (1000 psi?) -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Ray Andraka" wrote in message ... Gig 601XL Builder wrote: "Ray Andraka" wrote in message ... Gig 601XL Builder wrote: Fill them with Nitrogen they won't leak as much. Not that I've tried it. How do you figure that? Air is already mostly nitrogen. Why would a higher concentration of nitrogen leak any less than plain old air? The difference in atom sizes between nitrogen and the other major constituents of air is on the order of a few percent, so even the other constituents aren't going to leak out leaving just nitrogen. As I said I haven't tried it but there are 398,000 hits when you Google Nitrogen filled tires. I saw and ad for it in one of the aircraft mags the other day and hadn't really looked into it that much. But glancing at the Google results the opinions are mixed between works well and snake oil. There are reasons for using nitrogen in tires, but leakage isn't one of them. From what I understand, high pressure tires often need nitrogen because if regular air was used the high pressure of the oxygen mix becomes combustible and can lead to tire fires. In our spam cans though, the pressures aren't high enough to cause problems. There's also the convenience thing if you happen to have bottled nitrogen in the hangar, and finally some have said that it keeps the rubber from oxidizing, but I doubt that is a real issue since the outsides will deteriorate long before the inside oxidizes enough to be a problem. |
Shelf Life of [Spare] Tires? | [email protected] | Soaring | 8 | November 16th 05 07:03 PM |
airing tires | Fly | Owning | 6 | August 30th 05 04:24 AM |
Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 03:15 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
