I always replaced tires and tubes together. For the additional $30 for a
new tube, I always thought it was false economy to reuse them. As some have acknowledged, the tubes stretch and may fold upon reuse. I usually see cracking around the valve stem on a used tube. Perhaps reuse would be an option if we flew 250 hours a year and wore out tires sooner. But we usually have tires for 4 years or so. By then, I usually see the valve stem starting to crack and the sidewalls cracking on the tires. It seems like cheap insurance. But, others swear by reusing tubes. This is a pretty good case of how different people will accept differing degrees of maintenance. Absent any Advisory Circular or maintenance manual prohibition against reusing tubes, it is "legal" to do so. Nitrogen in the tires? I don't even use nitrogen in the struts. Good Luck, Mike |
Shelf Life of [Spare] Tires? | [email protected] | Soaring | 8 | November 16th 05 07:03 PM |
airing tires | Fly | Owning | 6 | August 30th 05 04:24 AM |
Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 03:15 AM |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
