I'm curious, though - with a lifting (i.e. positively-cambered) tail,
how do you avoid serious drag penalties and/or airflow disruption when deflecting the elevator upwards enough to induce negative Cl (...in other words, to have enough pitch-up control authority)? Everything I've read points towards needing a roughly balanced Cl range for adequate control authority in both pitch directions... I'm curious, but a little confused... Thanks! Take care, --Noel Jack wrote: With a lifting tail, the center of gravity can be moved aft for normal flight regimes. Jack Womack |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
