horiz tail airfoil observations
Old November 15th 06, 12:15 AM posted to rec.aviation.soaring
Brad
Default horiz tail airfoil observations
Is the fixed portion symmetrical but with a control surface that has a
slight undercamber on the bottom? That's what my ASH 26 elevator is
like, and I believe that is normal.
If the fixed portion is not symmetrical, is the flatter part on the top
or bottom?
the fixed portion is pretty much symetrical. the flatter part is on the
top surface
the upper part of the elevator is straight
the lower part of the elevator has a slight undercamber to it, like
what you normally see on the lower surface of a sailplane wing.
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old November 15th 06, 01:00 AM posted to rec.aviation.soaring
Eric Greenwell
or bottom?
top surface
This is consistent with the need to provide a down force, the usual case
for our gliders, so the airfoil is "upside down" compared to the wing.
As Udo pointed out, this is how the designer meets the requirement for
increasing "up elevator" force as speed increases. While this has a
safety advantage, the truly determined performance oriented pilot will
sometimes remove the undercamber to reduce drag. I've never wanted to do
it, because I want the safety advantage and I'm concerned the weight of
filler material might make the elevator flutter. It would take some
paperwork to make it legal, too.
Old November 15th 06, 01:14 AM posted to rec.aviation.soaring
Karl Striedieck
At a crazier age I tried eliminating all the undercamber in my ASW-25
elevator. This affected the pitch stability so drastically that when the
stick was released the only unknown was whether the impending loop would be
inside or outside! As pointed out, the under camber is there for pitch
stability and with passing decades the German airworthiness authority has
increased the forces. A Janus has lower pitch trim forces than a Duo Discus
for instance.
news:eFt6h.4796$T_.3143@trndny06...
or bottom?
top surface
increasing "up elevator" force as speed increases. While this has a safety
advantage, the truly determined performance oriented pilot will sometimes
remove the undercamber to reduce drag. I've never wanted to do it, because
I want the safety advantage and I'm concerned the weight of filler
material might make the elevator flutter. It would take some paperwork to
make it legal, too.
Old November 15th 06, 02:33 AM posted to rec.aviation.soaring
Hey Karl when you were totally banana's tell us the story of your 15M
ASW17 at 200knots thru the start gate.
Regards
Al
for instance.
or bottom?
top surface
make it legal, too.
Old November 15th 06, 01:42 AM posted to rec.aviation.soaring
Udo
Eric,
In this case the elevator and the shape is not just for safety but
also to maximize the performance, the airfoil was design as a
complete working unit. If there is a compromise it must be very small.
If you fly with the most optimum C of G there is very little elevator
deflection for the normal climb and speed range in a steady state and
if there is, let say -2 to + 2 deg of defection, I can tell you there
is no measurable drag penalty.
Udo
Old November 15th 06, 02:39 AM posted to rec.aviation.soaring
Eric Greenwell
Eric,
As I understand it, the drag penalty is not from the elevator deflection
(some of which would be required anyway), but because the airfoil is not
optimum for the lift (down force) it is producing; i.e., the undercamber
is on the side of the airfoil producing lift. There is always some drag
from the elevator, even with the control surface undeflected, because of
the lift (down force) it is producing.
Old November 15th 06, 09:06 PM posted to rec.aviation.soaring
Eric,
Hi Eric - I don't think this is correct. The prototype V2c I flew had a
trailing-edge tab bent down, explained to me as required for
appropriate
stick force gradient, as the elevator undersurface had no camber.
The production V2C tails added back the camber at a minor performance
penalty. Some well-known competition pilots in years back (not just
Karl)
did remove elevator camber for reduced drag, frightening the flutter
experts.
Hope that helps with the mystery,
Best Regards, Dave
PS: Jud, come out of hiding and explain it better to us
engineer-wanabees...
Old November 16th 06, 02:06 AM posted to rec.aviation.soaring
Brad
Hi Dave,
Hey...........now that you mention it, the elevator of that Krokus had
a bent down tab along the whole trailing edge, it was about .5" wide. I
don't quite recall if the lower surface of the elevator was flat or
curved tho......................there were 6 Blue Angels screaming by
and I was slightly distracted!
Cheers,
Brad
Eric,
appropriate
Karl)
experts.
Best Regards, Dave
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
