Brad wrote:
Is the fixed portion symmetrical but with a control surface that has a slight undercamber on the bottom? That's what my ASH 26 elevator is like, and I believe that is normal. If the fixed portion is not symmetrical, is the flatter part on the top or bottom? the fixed portion is pretty much symetrical. the flatter part is on the top surface This is consistent with the need to provide a down force, the usual case for our gliders, so the airfoil is "upside down" compared to the wing. the upper part of the elevator is straight the lower part of the elevator has a slight undercamber to it, like what you normally see on the lower surface of a sailplane wing. As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
At a crazier age I tried eliminating all the undercamber in my ASW-25
elevator. This affected the pitch stability so drastically that when the stick was released the only unknown was whether the impending loop would be inside or outside! As pointed out, the under camber is there for pitch stability and with passing decades the German airworthiness authority has increased the forces. A Janus has lower pitch trim forces than a Duo Discus for instance. "Eric Greenwell" wrote in message news:eFt6h.4796$T_.3143@trndny06... Brad wrote: Is the fixed portion symmetrical but with a control surface that has a slight undercamber on the bottom? That's what my ASH 26 elevator is like, and I believe that is normal. If the fixed portion is not symmetrical, is the flatter part on the top or bottom? the fixed portion is pretty much symetrical. the flatter part is on the top surface This is consistent with the need to provide a down force, the usual case for our gliders, so the airfoil is "upside down" compared to the wing. the upper part of the elevator is straight the lower part of the elevator has a slight undercamber to it, like what you normally see on the lower surface of a sailplane wing. As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() Hey Karl when you were totally banana's tell us the story of your 15M ASW17 at 200knots thru the start gate. ![]() Regards Al Karl Striedieck wrote: At a crazier age I tried eliminating all the undercamber in my ASW-25 elevator. This affected the pitch stability so drastically that when the stick was released the only unknown was whether the impending loop would be inside or outside! As pointed out, the under camber is there for pitch stability and with passing decades the German airworthiness authority has increased the forces. A Janus has lower pitch trim forces than a Duo Discus for instance. "Eric Greenwell" wrote in message news:eFt6h.4796$T_.3143@trndny06... Brad wrote: Is the fixed portion symmetrical but with a control surface that has a slight undercamber on the bottom? That's what my ASH 26 elevator is like, and I believe that is normal. If the fixed portion is not symmetrical, is the flatter part on the top or bottom? the fixed portion is pretty much symetrical. the flatter part is on the top surface This is consistent with the need to provide a down force, the usual case for our gliders, so the airfoil is "upside down" compared to the wing. the upper part of the elevator is straight the lower part of the elevator has a slight undercamber to it, like what you normally see on the lower surface of a sailplane wing. As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric, In this case the elevator and the shape is not just for safety but also to maximize the performance, the airfoil was design as a complete working unit. If there is a compromise it must be very small. If you fly with the most optimum C of G there is very little elevator deflection for the normal climb and speed range in a steady state and if there is, let say -2 to + 2 deg of defection, I can tell you there is no measurable drag penalty. Udo |
Udo wrote:
As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric, In this case the elevator and the shape is not just for safety but also to maximize the performance, the airfoil was design as a complete working unit. If there is a compromise it must be very small. If you fly with the most optimum C of G there is very little elevator deflection for the normal climb and speed range in a steady state and if there is, let say -2 to + 2 deg of defection, I can tell you there is no measurable drag penalty. As I understand it, the drag penalty is not from the elevator deflection (some of which would be required anyway), but because the airfoil is not optimum for the lift (down force) it is producing; i.e., the undercamber is on the side of the airfoil producing lift. There is always some drag from the elevator, even with the control surface undeflected, because of the lift (down force) it is producing. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() Eric Greenwell wrote: Udo wrote: As Udo pointed out, this is how the designer meets the requirement for increasing "up elevator" force as speed increases. While this has a safety advantage, the truly determined performance oriented pilot will sometimes remove the undercamber to reduce drag. I've never wanted to do it, because I want the safety advantage and I'm concerned the weight of filler material might make the elevator flutter. It would take some paperwork to make it legal, too. -- Eric, In this case the elevator and the shape is not just for safety but also to maximize the performance, the airfoil was design as a complete working unit. If there is a compromise it must be very small. If you fly with the most optimum C of G there is very little elevator deflection for the normal climb and speed range in a steady state and if there is, let say -2 to + 2 deg of defection, I can tell you there is no measurable drag penalty. As I understand it, the drag penalty is not from the elevator deflection (some of which would be required anyway), but because the airfoil is not optimum for the lift (down force) it is producing; i.e., the undercamber is on the side of the airfoil producing lift. There is always some drag from the elevator, even with the control surface undeflected, because of the lift (down force) it is producing. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org Hi Eric - I don't think this is correct. The prototype V2c I flew had a trailing-edge tab bent down, explained to me as required for appropriate stick force gradient, as the elevator undersurface had no camber. The production V2C tails added back the camber at a minor performance penalty. Some well-known competition pilots in years back (not just Karl) did remove elevator camber for reduced drag, frightening the flutter experts. Hope that helps with the mystery, Best Regards, Dave PS: Jud, come out of hiding and explain it better to us engineer-wanabees... |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
