Thin 3/8" wrench
Old November 17th 06, 12:52 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Thin 3/8" wrench
Sheesh! Airplanes are apparently a bargain....
Thanks for the information about a second class of bike wrenches.
Peter
"Cy Galley" wrote in message
news:nia7h.148036$aJ.132191@attbi_s21...
They make some very nice thin tool steel wrenches for Bikes. And they are
NOT for emergency use. Check at your local bike shop and look at the bikes
for $5 to 10 thousand dollars.
Cy Galley - Webmaster www.qcbc.org
"Peter Dohm" wrote in message
That's WRENCH, not wench you dirty minded garlic guzzling cigar
chomping
old
pharts.
I've got a very thin (0.050") 3/8" wrench that has been in my toolbox
since
Eisenhower. Over the years, it has rounded its jaws off to the point
where
it is fairly useless. The maker of the wrench, one H.H. Smith in
Brooklyn
NY no longer makes this tool.
Other than taking an ignition wrench and grinding it down, does anybody
have
a source for stamped thin metal wrenches?
I don't know where to buy a good one; but if you do have to grind down
an
ignition wrench, which is quite likely, be sure to use plenty of
coolant!
Otherwise the result is a very soft wrench, which is little better than
those stamped and punched things that are sold for emergency repair of
bicycles. :-(
Peter
Flight wrench question R.H. Piloting 14 June 25th 06 03:48 PM
FAA Fat Man on thin Ice StopPoliticallyCorrectTyranny Piloting 1 August 22nd 05 02:00 AM
Wrench size for KI214 & KI201 OBS knob Roy Page Owning 7 March 11th 05 10:07 PM
Descending through a thin icing layer Wyatt Emmerich Instrument Flight Rules 70 December 31st 03 05:17 AM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 04:35 PM
