*sigh* I had a very eloquent rant that I tried to post yesterday; but
for some reason it isn't showing up. I don't have the heart to try to reconstruct the entire rant, so I'll summarize: It seems there only two types of aircraft design books/articles: 1) Those that use ballpark figures and rely on historical examples of existing designs --OR-- 2) Those designed for engineers, with accurate but very complicated equations in Engineering notation that are indecipherable by the layman. Is it so hard to bridge the gap, for those of us that can't decode long strings of Greek letters into practical terms? I'm a computer professional, so I'd like to think I'm decent with math - but even 3d-graphics-programming has only required a solid grasp of algebra, trigonometry, and matrix math. The calculus and short-handed equations in many technical articles might as well be modern art on the page, for all I can tell. Many factors are often not defined by the author - who assumes the reader knows what they mean; even those targetted at "first time" designers! In terms of this tail issue, for example, is it really too hard to put it in terms like... "At speed ____ your design would have to pull a Cl of ___, requiring an angle of attack of ____. With the airfoil chosen, the coefficient of moment in this situation is ____. Applying equation _____________ to that and the Center-of-Gravity at ___, you end up with a total pitching force of ____. This must be counter-balanced by the tail producing an equal and opposite amount of force. Given the wing downwash effects and angle of incidence, the horizontal stabilizer is flying at an angle of attack of ____. So to provide enough force, the coefficient of lift must be ____ and/or the tail area must be ____ (assuming no elevator deflection). " I mean, am I missing something; or can't you put it into those simple and direct terms? I guess I've left out is the stability margin - but that's got to be something you can factor into the above process, right? Surely such a direct-calculation approach would require iterative design to find the optimal solution in all flight regimes - but even that is better for the amateur designer than an inverse solution that cannot be solved by the average joe! Somebody please feel free to step up and slap me if I'm way off base here.... I've got a good wing design, a good fuselage, and a good vertical tail; all with numbers that I can calculate and verify - but I've been wrestling with this horizontal tail issue for a week and its really getting to me! Thanks, take care, --Noel |
![]() noel.wade wrote: *sigh* I had a very eloquent rant that I tried to post yesterday; but for some reason it isn't showing up. I don't have the heart to try to reconstruct the entire rant, so I'll summarize: It seems there only two types of aircraft design books/articles: 1) Those that use ballpark figures and rely on historical examples of existing designs --OR-- 2) Those designed for engineers, with accurate but very complicated equations in Engineering notation that are indecipherable by the layman. Is it so hard to bridge the gap, for those of us that can't decode long strings of Greek letters into practical terms? I'm a computer professional, so I'd like to think I'm decent with math - but even 3d-graphics-programming has only required a solid grasp of algebra, trigonometry, and matrix math. The calculus and short-handed equations in many technical articles might as well be modern art on the page, for all I can tell. Many factors are often not defined by the author - who assumes the reader knows what they mean; even those targetted at "first time" designers! In terms of this tail issue, for example, is it really too hard to put it in terms like... "At speed ____ your design would have to pull a Cl of ___, requiring an angle of attack of ____. With the airfoil chosen, the coefficient of moment in this situation is ____. Applying equation _____________ to that and the Center-of-Gravity at ___, you end up with a total pitching force of ____. This must be counter-balanced by the tail producing an equal and opposite amount of force. Given the wing downwash effects and angle of incidence, the horizontal stabilizer is flying at an angle of attack of ____. So to provide enough force, the coefficient of lift must be ____ and/or the tail area must be ____ (assuming no elevator deflection). " I mean, am I missing something; or can't you put it into those simple and direct terms? I guess I've left out is the stability margin - but that's got to be something you can factor into the above process, right? Surely such a direct-calculation approach would require iterative design to find the optimal solution in all flight regimes - but even that is better for the amateur designer than an inverse solution that cannot be solved by the average joe! Somebody please feel free to step up and slap me if I'm way off base here.... I've got a good wing design, a good fuselage, and a good vertical tail; all with numbers that I can calculate and verify - but I've been wrestling with this horizontal tail issue for a week and its really getting to me! Thanks, take care, --Noel I have wrestle with that my self. I had no background in it when I started and still my knowledge is very narrow. But over 25 years I have bulldoze my way through. 17 years ago things started slowly changing for me, aside for rudimentary formulas. With the advent of ACAD and aerodynamic software as well as the internet, things started to fall into place. To day I use a 2D and a 3D software. Both of them are commercial programs. Combined with subscriptions to Technical Soaring and other publications I slowly started to make sense of it. The results were, two projects that were limited to changing airfoils. My new project starts from scratch. For it to be fine tuned a rely on the 3D software, as well as what is out there on the flight line. Udo PS. Go to the Glider Tech Group, a Yahoo group. I just listed a file comparing the DU13.7-86 vs. the FX71-150/30 for two speeds with values that are appropriate for those speeds |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
