backup for vacuum pump/attitude indicator failure
Old November 20th 06, 06:43 PM posted to rec.aviation.owning,rec.aviation.ifr
Dave Butler[_1_]
Default backup for vacuum pump/attitude indicator failure
Maule Driver wrote:
I have the precise flight setup. I've never had to use it but, my sense
is that the vacuum failure light may be the most valusable component.
The light is good if you don't have one.
Directed to the OP (I'm sure MD knows this):
If you go with the Precise Flight, be sure you check the shuttle valve
frequently as described for preflight in the POH Supplement. The shuttle
valve can stick and then when you need it, it doesn't work. Just the act
of checking it causes the valve to operate and probably helps keep it
from sticking.
Also be sure you understand the operating limitations - altitudes and
power settings where it works and doesn't.
Old November 21st 06, 11:15 PM posted to rec.aviation.owning,rec.aviation.ifr
Andrew Gideon
I have to say: I don't like this system. One time when you want happy
gyros is when low and busy...like on a missed approach. But the
full-throttle of the missed means that the gyros are spinning down.
Plus, of course, there's the fact that it does nothing for an AI or
plumbing failure.
- Andrew
backup for vacuum pump/attitude indicator failure Kelly Owning 27 November 29th 06 06:58 AM
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
Fllight Recorder Wars, Part II: What Backup to Use? Chip Bearden Soaring 13 March 31st 04 10:10 PM
Good AI backup, wish me luck Robert M. Gary Instrument Flight Rules 29 March 1st 04 05:36 PM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 09:53 PM
