At the coldest place in the carb. It depends where the
probe is installed. If in the throat, then you might want to see 100° F, if at the throttle plate /venturi, then just solidly above freezing. "Newps" wrote in message . .. | | | Jim Macklin wrote: | | Using carh heat on the ground, | | In cruise flight carb heat should be set to give a carb temp of approx | 45-50F. |
![]() "M" wrote in message ups.com... A very high pressure settled in Pacific NW: KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2 SLP389 T10671078 That's the highest that I've ever remember seeing. I always thought that the NW seems to have larger pressure swings (probably more so in Alaska). We can go from 2960 to 3060 in about two days. Actually got out and practiced in the pattern a little bit today with my instructor, but since he isn't allowed to instruct in our clubs planes, we were splitting time (we did my primary instruction through a different club). Altimeter setting when we started up at Renton Municipal (KRNT) was "30.64", and remember sitting there thinking, "hmmm... I wonder if it goes that high???" During our second trip around the pattern, they updated the ATIS and it dropped a little bit to "30.62" Fog was being stubborn to burn off today, as we were going to go at 10am, but Renton was fogged in and it didn't go away until about noon, and as we were in the patter could see there still a good deal of fog to the south. Have to say it was nice to get out today, as it was the first time in 6 weeks that I had flown, and thought I might be kind of rusty being a sort of low time pilot, but all of my landings were great and the base to final turns were all pretty much right on the glide slope and on the centerline, with the exception of the second, which I overshot the base-final turn, but I just continued a nice coordinated turn and didn't try to rush it as I had plenty of room to get lined up and fix the problem. |
![]() " A very high pressure settled in Pacific NW: KPSC 020453Z 31006KT 6SM BR BKN007 BKN075 M07/M08 A3066 RMK AO2 SLP389 T10671078 That's the highest that I've ever remember seeing. Yeah with terrible smog to go along with it. Once you get to 1-1.5K and look down it's almost like a fog bank it's so dense. We're getting as bad as Los Angeles :-( Cheers: Paul N1431A 1S0 |
You are flying VFR at 17,500 MSL with an altimeter setting of 30.66. You
pick up an IFR clearance and are given FL190. You begin a slow climb. As soon as you pass 18,000 MSL you set your altimeter to 29.92. It now reads 17,300 so you set it back to 30.66. It now reads 18,000, so you set it back to 29.92. I now reads 17,300 ... Conclusion: It's impossible to get above 18,000 MSL if the altimeter setting is 30.66. |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
Local altimeter at BFM | Dan Luke | Instrument Flight Rules | 3 | June 15th 04 02:01 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 07:58 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
