![]() wright1902glider wrote: You might also try a left-hand (that is the reverse of standard, right?) drill bit. HF sells 'em, and you may also find them packaged with a set of EZ-outs at the BLUE or ORANGE stores. That might work if the screws aren't corroded into the holes. If there's enough of a screw left, I've also had mixed results filing flats on the screws 180 degrees opposed, and grabbing on with a crescent wrench or vice-grips. Careful, don't break the screw off a second time like I did. You might also try drilling with cutting fluid. I had a similar experience trying to drill out a set of rivets holding the ball joints into my Dodge. (Wadda they make those damn rivets out of anyway?) With the hand-electric drill it took 27 broken bits and 4 days. When I did the other side, I pulled the a-arm out of the truck, mounted in a vise on the drill press, and then drilled down using a 1/64" cobalt bit and cutting fluid. It only took about 5 minutes per hole using 7 different sized bits to achieve the same results. I wasn't using any more pressure or speed with the drill press. So maybe the cutting fluid is a semi-magic bullet? Excellent advice, there Wright 1902. Thanks a lot. I'll run to the HF store and see what I can find. Something's gotta work. |
Sears has a nice set of extractors called "Power Extractors" that go
down to #40 size. In the small sizes, they have a left hand drill on one end, and a fluted extractor on the other. I have used them to remove many a broken and stuck screw on my plane and they work well. The product # is 00952155000 on the Sears website. Also this webpage has it. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes Most Sears stores I have looked in have them. Regards, Bud jls wrote: wright1902glider wrote: You might also try a left-hand (that is the reverse of standard, right?) drill bit. HF sells 'em, and you may also find them packaged with a set of EZ-outs at the BLUE or ORANGE stores. That might work if the screws aren't corroded into the holes. If there's enough of a screw left, I've also had mixed results filing flats on the screws 180 degrees opposed, and grabbing on with a crescent wrench or vice-grips. Careful, don't break the screw off a second time like I did. You might also try drilling with cutting fluid. I had a similar experience trying to drill out a set of rivets holding the ball joints into my Dodge. (Wadda they make those damn rivets out of anyway?) With the hand-electric drill it took 27 broken bits and 4 days. When I did the other side, I pulled the a-arm out of the truck, mounted in a vise on the drill press, and then drilled down using a 1/64" cobalt bit and cutting fluid. It only took about 5 minutes per hole using 7 different sized bits to achieve the same results. I wasn't using any more pressure or speed with the drill press. So maybe the cutting fluid is a semi-magic bullet? Excellent advice, there Wright 1902. Thanks a lot. I'll run to the HF store and see what I can find. Something's gotta work. |
![]() Lots of good advice given but there's one problem that hasn't been addressed. That's keeping the drill bit in the broken screw and not letting it wander off into the spar. if the screw has been broken off under flush there's not an easy way of dressing up the surface for a good start. To keep from really messing up the job you may want to make a drill guide to keep the bit aligned and going straight into the broken screw. A piece of 1/2" square steel stock about 8" long from any hardware store will do. Set it up in a drill ress and drill a hole the size of the bit you want to use through one side directly through. Set the bar on the spar and line up the hole over the broken screw and then clamp the bar down securely to the spar flange. Now you can drill through the bar into the broken screw with far less chance of needing one of those special figure eight shaped screws to cover the mess you made. Any good quality SHARP drill bit will do the job with the correct technique. For drilling out steel screws, use a slower RPM and more pressure than for drilling aluminum. Start with a couple of light taps at high RPM to ensure the drill gets a good center on the broken screw shank or use a small center punch that will fit through the guide. Using cutting oil is a good idea. I don't think the Craftsman extractors are small enough for a #4 screw. I would go with a left handed bit, mouse milk, and take my time. |
On 2 Jan 2007 03:34:14 -0800, "Charles" wrote:
Lots of good advice given but there's one problem that hasn't been addressed. That's keeping the drill bit in the broken screw and not letting it wander off into the spar. if the screw has been broken off under flush there's not an easy way of dressing up the surface for a good start. To keep from really messing up the job you may want to make a drill guide to keep the bit aligned and going straight into the broken screw. A piece of 1/2" square steel stock about 8" long from any hardware store will do. Set it up in a drill ress and drill a hole the size of the bit you want to use through one side directly through. Set the bar on the spar and line up the hole over the broken screw and then clamp the bar down securely to the spar flange. Now you can drill through the I would suggest using a "center drill" that just nicely fits the hole in the steel plate at this point. It won't wander and will create a nice cone shaped indentation in the screw shank. Then switch to a drill and metal plate with a hole that fits the drill. A good sharp drill *should*follow the screw bar into the broken screw with far less chance of needing one of those special figure eight shaped screws to cover the mess you made. Any good quality SHARP drill bit will do the job with the correct technique. For drilling out steel screws, use a slower RPM and more pressure than for drilling aluminum. Start with a couple of light taps at high RPM to ensure the drill gets a good center on the broken screw shank or use a small center punch that will fit through the guide. Using cutting oil is a good idea. I don't think the Craftsman extractors are small enough for a #4 screw. I would go with a left handed bit, mouse milk, and take my time. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
I just looked, and the Craftsman extractors I referenced go down to a #
5 screw. It had a reference for a size smaller than #6, and I thought it was a #4, but alas. Bud Charles wrote: Lots of good advice given but there's one problem that hasn't been addressed. That's keeping the drill bit in the broken screw and not letting it wander off into the spar. if the screw has been broken off under flush there's not an easy way of dressing up the surface for a good start. To keep from really messing up the job you may want to make a drill guide to keep the bit aligned and going straight into the broken screw. A piece of 1/2" square steel stock about 8" long from any hardware store will do. Set it up in a drill ress and drill a hole the size of the bit you want to use through one side directly through. Set the bar on the spar and line up the hole over the broken screw and then clamp the bar down securely to the spar flange. Now you can drill through the bar into the broken screw with far less chance of needing one of those special figure eight shaped screws to cover the mess you made. Any good quality SHARP drill bit will do the job with the correct technique. For drilling out steel screws, use a slower RPM and more pressure than for drilling aluminum. Start with a couple of light taps at high RPM to ensure the drill gets a good center on the broken screw shank or use a small center punch that will fit through the guide. Using cutting oil is a good idea. I don't think the Craftsman extractors are small enough for a #4 screw. I would go with a left handed bit, mouse milk, and take my time. |
misdrilled hole on on tubular aluminum spar question | patrick mitchel | Home Built | 12 | October 2nd 06 08:17 PM |
Question about Alodine 1201 | Andrew Sarangan | Home Built | 20 | April 11th 06 01:31 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
