The initial lean should be very quick. It's called the "Big Pull." Fine tune as slow as you need to. You need to avoid the red box, that's why you lean quickly.
I've only heard of a red fox, not a red box. What is that? In general, I lean to a bit richer than I ought to be, and then after it stabilizes, I lean from there. But if you overshoot, that's not good. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
What really happens when you go towards peak EGT is you're assuring a
pretty efficient burn inside the cylinders, the exhaust contains little unburnt fuel and little oxygen. If you play a little with the mixture when prop and throttle are firewalled you'll probably pick up some RPM, even at low altitudes. It's especially noticable on hot days. In cruise with constant speed props the prop pitch changes a little, taking a healthier bite of the air so as to use the additional power. CHT is a simple way of measuring what's going on -- it's telling you, as you go from rich to lean, when you're getting the hottest -- call that best -- internal temps. Since the fuel (I was taught) helps in cooling, you want not to overlean so as to save the valves. That statement probably deserves some research -- why not run schiometric (I'm sure I mis spelled that) combustion? Does anyone know for sure? For that matter, if you do get peak power at max EGT, why run on the rich side? Wouldn't it make sense in terms of fuel economy to run on the lean side a bit? I know the dogma, what I'm interested in is the justification. Any powerplant engineers out there? |
rich side? Wouldn't it make sense in terms of fuel economy to run on the lean side a bit? I know the dogma, what I'm interested in is the justification. Any powerplant engineers out there? Google "lean of peak". There is a company out there (whose name escapes me right now) that makes engine gauges that are supposed to be so good you can run LOP safely. The issue is that =at= peak, the temperatures get too hot in the cylinders, and if you don't run cool enough in the one cylinder that is being measured by the ordinary gauges, you are likely to be running too hot in at least one of the others. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() Jose wrote: Google "lean of peak". There is a company out there (whose name escapes me right now) that makes engine gauges that are supposed to be so good you can run LOP safely. It's not the gauges, it's the fuel distribution. In order to run LOP effectively each cylinder must peak at the same, or damned close, fuel flow and therefore at the same time. |
Yep, you're right. And this usually requires an engine mod, since stock airplane engines are not very uniform. In any case, don't these mods also come with a gauge for each cylender? Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() Jose wrote: It's not the gauges, it's the fuel distribution. In order to run LOP effectively each cylinder must peak at the same, or damned close, fuel flow and therefore at the same time. Yep, you're right. And this usually requires an engine mod, since stock airplane engines are not very uniform. In any case, don't these mods also come with a gauge for each cylender? No, the GAMI's are six injectors that replace the standard six. They reccomend an engine monitor but it's not necessary. As it happens I can run real nice LOP without having to buy the GAMI's. |
"Newps" wrote in message
. .. Jose wrote: It's not the gauges, it's the fuel distribution. In order to run LOP effectively each cylinder must peak at the same, or damned close, fuel flow and therefore at the same time. Yep, you're right. And this usually requires an engine mod, since stock airplane engines are not very uniform. In any case, don't these mods also come with a gauge for each cylender? No, the GAMI's are six injectors that replace the standard six. They reccomend an engine monitor but it's not necessary. As it happens I can run real nice LOP without having to buy the GAMI's. It's been much too long since I've known, and I'm too lazy to look it up on New Year's Eve, but aren't GAMI injectors usually installed using an engine monitor to obtain the best match for each injector and cylinder combination? After the inital shop work with an analyzer/monitor, the use of an engine monitor by the aircraft operator is recommended, but not required--exactly as you stated. BTW, I've always presumed that the advantage of a set of GAMI injectors was simply that they guaranteed a matched set; but you could also have a similarly matched set of stock injectors by carefull selection from a sizeable batch, or simply by fortunate happenstance. Is this your real world experience, or are you basically using the "hottest cylinder" method, or both? Peter |
Tony writes:
For that matter, if you do get peak power at max EGT, why run on the rich side? Wouldn't it make sense in terms of fuel economy to run on the lean side a bit? Aside from the most fuel-efficient mixture settings, which settings are the _safest_? Which settings put the least wear and tear on the engine? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Jose wrote: The initial lean should be very quick. It's called the "Big Pull." Fine tune as slow as you need to. You need to avoid the red box, that's why you lean quickly. I've only heard of a red fox, not a red box. What is that? At and below 60% there is no red box, put the mixture anywhere you want. At 65% power use richer than 100 ROP or leaner than peak. At 70% power use richer than 125 ROP or leaner than 25 LOP. At 75% power use richer than 180 ROP or leaner than 40 LOP. At 80% power use richer than 200 ROP or leaner than 60 LOP. As you transition from takeoff power to cruise power if you are going to be LOP make sure you lean rapidly to the values listed for LOP ops. Fine tune as necessary. |
Ok. My comments were for ROP operations, which is what all the aircraft I use reccomend. In that case, you should never hit the red box, and should lean slowly. If you lean quickly and overshoot, you'll be in the red box. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Emergency Procedures | RD | Piloting | 13 | April 11th 04 08:25 PM |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
