LPV vs LNAV/VNAV?
Old January 6th 07, 04:00 PM posted to rec.aviation.ifr
Paul kgyy
Default LPV vs LNAV/VNAV?
Both of these options require a WAAS receiver, I presume?
Old January 6th 07, 05:31 PM posted to rec.aviation.ifr
Sam Spade
Yes, and if WAAS is not available to the standards required by the specs
then the 146 box will not accept the WAAS solution, which means (using
Garmin as an example) LPV, L/VNAV, and LNAV+V will not be available;
only LNAV will be available.
Old January 6th 07, 07:35 PM posted to rec.aviation.ifr
John R. Copeland
"Sam Spade" wrote in message ...
And I can attest to that, Sam, because I've experienced having an
LNAV/VNAV approach "Downgraded to LNAV" only.
I couldn't take the time just then to check the SV reception page,
to see if the problem might have been explained there.
Old January 6th 07, 08:51 PM posted to rec.aviation.ifr
Mike Adams[_2_]
I don't think so. A TSO C129a GPS driving a FMS with baro VNAV should be able to fly RNAV(GPS)
approaches using LNAV/VNAV minimums. No WAAS involved.
Mike
Old January 7th 07, 02:14 PM posted to rec.aviation.ifr
Sam Spade
Mike
That has been true for a long time. The context of the recent
discussions in this forum have been about TSO C-146 (RTCA DO-229C).
Old January 7th 07, 02:50 AM posted to rec.aviation.ifr
Andrew Sarangan
Something I never understood is why LNAV approaches don't automatically
show a glideslope so that the airplane arrives at the MDA at the VDP.
Old January 7th 07, 02:53 AM posted to rec.aviation.ifr
Mxsmanic
Andrew Sarangan writes:
Because L stands for lateral?
Old January 7th 07, 04:48 AM posted to rec.aviation.ifr
Peter R.
Perhaps because it wasn't part of the certification at the time?
Peter
Old January 7th 07, 05:33 AM posted to rec.aviation.ifr
Andrew Sarangan
Perhaps my comment was not clearly stated. When you fly an LNAV
approach (or any nonprecision approach for that matter) instead of the
traditional dive and drive you can mentally calculate the vertical
speed required (VSR) to arrive at the VDP at a constant glide angle .
That mental calculation could be easily performed by the GPS and
displayed as a glideslope. But I have not seen any GPS do that.
Certification is irrelevant. We are not talking about a lower minimum
or anything new that we not already allowed to do.
Old January 7th 07, 05:57 AM posted to rec.aviation.ifr
Peter R.
Certification is most certainly relevant to your query, as that is most
likely what kept that feature out of the TSO C129a certified IFR GPS's.
A handheld Garmin 196 (I think that is the model a pilot-friend had with
him a couple of years ago) that we took up on a practice IFR flight did
just that. It displayed a glideslope for a non-precision approach. If the
cheaper handhelds can do it, then why don't their IFR-certified TSO C129a
big brothers do it? Because it wasn't part of the certification and
therefore, regardless of their ability to provide this feature, are
restricted from doing so due to the certification.
Peter
LNAV, VNAV and LPV Andrew Sarangan Instrument Flight Rules 5 January 14th 07 01:57 PM
LNAV preferable over LNAV/VNAV [email protected] Instrument Flight Rules 4 October 16th 05 06:34 PM
GPS approaches with VNAV vertical guidance Doug Instrument Flight Rules 18 November 2nd 04 10:36 PM
CNS-80 VNAV John R. Copeland Instrument Flight Rules 17 October 28th 04 04:24 AM
Which GPS Support LNAV/VNAV? C Kingsbury Instrument Flight Rules 1 October 23rd 04 12:28 AM
