TxSrv writes:
What's the default position in my 1972 American AA-5 Traveler? No mention of it in the Pilot Operating Handbook. I know. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
TxSrv writes: What's the default position in my 1972 American AA-5 Traveler? No mention of it in the Pilot Operating Handbook. I know. You know what? It's "default position," or that this odd and irrelevant piece of information is not in the POH? F-- |
TxSrv writes:
You know what? It's "default position," or that this odd and irrelevant piece of information is not in the POH? I know that it's not in the POH. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
I know that it's not in the POH. Then you may have read my plane's POH, but certainly have never flown one. Else you'd know how trim works and why there's no "default position." F-- |
see
http://www.faa.gov/library/manuals/a...A-S-8083-1.pdf W&B handbook and http://www.faa.gov/library/manuals/a...lane_handbook/ and http://www.faa.gov/library/manuals/a...a/ac90-89a.pdf am. flight testing "TxSrv" wrote in message . .. | Mxsmanic wrote: | | I know that it's not in the POH. | | Then you may have read my plane's POH, but certainly have | never flown one. Else you'd know how trim works and why | there's no "default position." | | F-- |
TxSrv wrote:
Then you may have read my plane's POH, but certainly have never flown one. Else you'd know how trim works and why there's no "default position." Okay, now that I've made the mistake of reading this discussion, you've got me curious: How does your plane's trim work? It's obviously not a trim tab. And how can there be no neutral/default position of the elevator or the trim device? |
Anno v. Heimburg writes:
Okay, now that I've made the mistake of reading this discussion, you've got me curious: How does your plane's trim work? It's obviously not a trim tab. And how can there be no neutral/default position of the elevator or the trim device? The neutral position of a trim tab is the position in which it does not intefere with the flow of air over the control surface, and thus does not deflect the control surface in either direction. There is no default position of a trim tab, as it is set as appropriate for circumstances, which vary widely. In my use of the term, I was thinking of trim positions that compensate for specific power and pitch configurations and the like, excluding those that compensate solely for a poorly balanced payload or fuel load. In other words, I make a distinction between trim used to maintain the aircraft in a specific, normal flight configuration, and trim used to keep the nose from pitching violently upward because there's so much junk loaded in the back of the aircraft (or violently forward because the pilot and copilot are heavy and there's no ballast behind them). As I understand it, the manufacturer's CG envelope is designed to ensure adequate remaining control authority for any CG within the envelope. I'm not sure how they determine what is adequate, however, so I still worry. Which is why I'd like the most neutral CG possible, that is, the one that has the least tendency to induce pitch or roll movements. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
The neutral position of a trim tab is the position in which it does not intefere with the flow of air over the control surface.... A trim tab does not necessarily "interfere" with the flow of air over a control surface. You need to read Hoerner's books. F-- |
Anno,
And how can there be no neutral/default position of the elevator or the trim device? Ok, you got me curious. No default position in all Cessnas I have flown. Not in the Bo. Nor in the Tobago. Not in the Cirrus nor the DA-40 or the -20. Nor any other plane I can remember INCLUDING the big airliners in MSFS. WTF are you talking about? There's a marking for take-off, alright. But that'S not what we're talking about. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Ok, you got me curious. No default position in all Cessnas I have flown. Not in the Bo. Nor in the Tobago. Not in the Cirrus nor the DA-40 or the -20. Nor any other plane I can remember INCLUDING the big airliners in MSFS. The position where the control surfaces align with the stabilizer, that is, no deflection upwards or downwards. At least that's what I interpreted the expression to mean. I freely admit I'm clueless, though. NB that I'm not saying that this position is necessarily marked anywhere, nor that it is relevant to actually flying the plane. |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Pocket PC Weight and Balance Spreadsheet | Navzilla Support | Piloting | 0 | October 9th 05 11:47 PM |
Cessna 172 F Weight and Balance | [email protected] | Owning | 8 | September 22nd 05 02:38 AM |
172S Weight and Balance Question | David J | Piloting | 9 | March 23rd 04 01:08 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
